View Poll Results: If you've Overheated What is Your Stage Aero 1, 2 or 3
Voters: 348. You may not vote on this poll
ZO6 overheating issues ***MEGA Merge***
#2121
Brutal. Sorry to hear.
#2122
You could do a roof oil cooler like this:
Or like this:
Just a suggestion, We promise we won't laugh.
Doug
Or like this:
Doug
#2123
So basically, everyone is going to "fix" their overheating by removing all the aerodynamic pieces that manage airflow through the cores and back out of the car...ok then...
If all else fails, you can remove the hood next...that'll help.
#2124
Scraping the splitter.
I think an insulated, somewhat snap-on,form fit cover for the PS unit would probably solve it. This would have a heat reflective barrier and weigh probably a few ounces. Think similar to starter shields.
S.
S.
#2125
What about something like this?
http://www.thermalprotectioninc.com/...ive_Films.html
More like this IMO...
https://www.designengineering.com/ca...s/versa-shield
S.
#2128
You don't want to lock heat in if it is motor generated.
Doug
#2129
Not sure, but would suspect it does not help that it is sandwiched between the front of the engine and the radiator with the lower radiator hose 2-fingers away.
S.
S.
#2130
Why should anyone have to research which part to add to cool this dreaded Z06 heating issue?? Hell, I wouldn't put another dime into this car after spending my hard earned money on it. I'd tell GM to buy the car back including tax, title and license fees.
I sure won't be buying a C7 Z06 until all this nonsense bs it fixed BY GM.
I'll stick with my current rides.
#2132
End of day update. We drove in "M" all day and had no overheating warnings or power steering failures. Ambient temps ended up being low 80s with a breeze.
In the last session of the day, we saw max oil temps of 303*, but water only hit 255, so no warnings/failures. Still, pretty close to the limit-- even with paddle shifting. Another 5-10* warmer ambient might well have changed the outcome.
For reference, we were working the car pretty hard. The other driver did a 1:54 lap, which is just nutty fast for Thill in a stock production car.
#2133
I saw an interesting idea for improving airflow on mikymu's C6. Instead of removing the weather strip completely, he cut sections out leaving sections to support the hood. Looks like a good idea. Also, the plastic piece under the hood vents should probably be removed. That and the hood insulation itself...although that could put paint at risk?
I drove the 5 mile course (first time) on Friday and had zero issues. Upper 70s and shifted manually. Lack of familiarity with 2 miles of the track definitely helped. I was in the 3:40 range. Quick race prepped C-6s were probably in the 3:20s. I was hitting 260s versus their 230s for oil temps.
D not recommended if over 70 degrees and driving well.
#2134
Just a thought on the power steering - if the variable power assist works the way I think it does (less motor current equates to more steering effort, ie, track mode), it's probably a good idea to make sure the steering effort is always set to track mode at the track. Less motor current means less internal heat generation. I've been in the habit of manually setting my steering to Sport mode on the street, regardless of the mode the car is actually in. I'll have to remember to change this back at the track.
Also, tracks that require more steering, or holding the steering wheel off-center for longer periods, will probably be worse for internal motor heat generation. I don't think we know yet whether the issue is internal power steering heat generation, external heat soak to the PS unit from the hot engine compartment, or some combination of both.
#2136
Good info. Driving my manual C5Z a gear higher in "some" spots on the track does untold wonders for oil temperatures. The A8 in our C7Z's can just be ridiculous for holding the revs up. Mine's hitting the track for the first time later this month, will take your advice and go with Manual mode.
#2138
I have prepped the car EXACTLY as specified in the Owners Manual. I SCRUPULOUSLY follow the instructions from the car's warnings and indications. If I experience power train problems before 100K miles, I expect GM to honor my warranty. :-)
I really don't want to have to modify the car and run the risk of being second-guessed in three years if something blows up.
#2139
No.
S.
#2140
I'm not sure where trans oil overheats, but I don't think it is the weakest link.
