View Poll Results: If you've Overheated What is Your Stage Aero 1, 2 or 3
Voters: 348. You may not vote on this poll
ZO6 overheating issues ***MEGA Merge***
#4021
HUH???
#4022
I make it a habit when I pull my C7 into the garage I always pop the hood and open it to let the heat out. LT4's have a lot of heat soak mainly because of the supercharger.
#4023
This car is a disaster...
#4025
The Consigliere
Received 5,447 Likes
#4026
#4028
Now that we have been "mega merged" again let me make it clear I am responding to this sub-thread in the mega-heativerse:
" Originally Posted by maherjad
When driving in 90+ degree weather I can feel the engine is running very hot, even after its back in the garage it’s hot for hours. I heard its normal but I still don’t like it. Is it good idea to change or take out the thermostat, is that a good option someone tried?"
I think at most dealerships no matter how explicitly you explain issues to the service writer what the service writer conveys to the tech is similar to how the OP has explained the issue to us
This is why I always attach a written note to the tech inside my cars to make sure the problem isn't translated into "gibberish" by the service writer.
#4029
Uh, I would believe that after a spirited run a hot exhaust is quite common. If you think the tips get hot, check out the temps of the exhaust manifolds.
#4031
Motor Trend Overheats Another Corvette Z06
The Corvette Z06 overheating issue is now a lot like global climate change.
Read the rest on the CorvetteForum.com homepage. >>
#4033
I installed a Dewitt radiator, thermal plates, intercooler/tank and still overheat after 3 laps at Streets of Willow. My solution was I bought a new Caymen GTS for track days and use my A8 Z06/07 for street use. I'm VERY disappointed with GM any myself for believing this was a track ready car. This is my first and last corvette I'll ever own. I'm patiently waiting for an intelligent fix or GM to say its normal to overheat in 3 laps. I like the the car but was told it's something that is not.
#4034
#4036
#4037
IMO the real fix can only come from GM or possibly Callaway via heavy duty engineering and execution. Swapping out parts for aftermarket or adding a vent here and there is all band aid fixes that potentially could endanger your warranty.
#4039
Warranty an overheating track car that was designed for.. The track. Personally I'd stroke it build a high rpm big bore na solid roller. Burn that blower.or run it over . Would make a viral YouTube video.
#4040
Overheating GM - Service bulletin..
I have a A8 Z07 and I can have the engine to overheat within a couple of laps (and I leave in Canada where the summers are warm). If I switch to manual paddles, it is the power steering that will overheat... This is very frustrating. So I call my dealer to report the issues, and this is the note I got back:
Does the US dealers have the same bulletin? Anyway, it seems that GM is telling us to shut-up!
Sorry if it is a repost but I couldn't find it in this thread...
