Trying to pick headers - looking for input
Kooks, ARH, or LG ?
What size ? I'm getting lots of conflicting advise from the tuners I've called. Hennessey says 1-3/4. One guy at LG says 1-3/4", another says 1-7/8. Lingenfelter says 1-7/8 or 2".
I'm planning on long tubes with hi flow cats. Just need to pick a brand and size
Anyone have any advise or experience with these brands?
I'm assuming who ever you spoke with knew it was going on a Z06, if that was the case then the choice should be 1 7/8, although both fit the car.
All of our big power/supercharged applications have used the larger headers.
LG Motorsports Super Pro 1 7/8 C7
Contains all four OEM 02 bungs and includes Wide Band bung on the driver side at no extra cost
OEM muffler connections
- High Flow Merge collector with fiire cone
- 3" header collector
- 3" high flow Siamese X pipe design
- off-road pipes, or optional high flow 3" cats
- Includes GM gaskets
- Includes 02 extensions
- Stainless construction
- Limited lifetime warranty
- Connects to OEM or OEM replacement mufflers
Thanks for the info. How do you feel about 2"? I've got a Halltech intake, 15% overdrive pulley, and the headers as probably all I will do on this car..
We'd be very happy to discuss which system is best based on your specific needs.
PM sent.
https://www.corvetteforum.com/forums...7-headers.html
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Fit, form, and function they're all the same.. They exhaust (no pun intended) however, if you look closely at the materials as well as design they're slightly different. As far as size goes.., most will tell you sub 900hp applications use 1-7/8" buuuuut... How much torque do you really need? If I were in your shoes I'd buy 2" and call it good. Pick a brand you like their advertisement the best and you'll be happy you chose those. I chose Kooks because I go a better deal on them. Hope this helps.
