Reason for engine failure
Old Aug 24, 2015 | 02:26 PM
TRT SR's Avatar
TRT SR
Default Reason for engine failure
Chevrolet finds cause and solution for Corvette Z06 engine problem
Fox News
By Gary Gastelu
Aug. 21, 2015
After bringing it back to Chevrolet HQ for inspection, the engineers determined that the likely cause was a piston connecting rod bearing that was damaged by debris in the oil that was left behind after tapping the threads for the oil filter. Once a piece gets jammed in there, it starts creating more debris, which keeps making things worse until finally … kablooey. In this case, it took out a few more pistons with it. http://www.foxnews.com/leisure/2015/...ngine-problem/
Sorry if this has been posted before
Old Aug 24, 2015 | 02:44 PM
BOBSZ06's Avatar
BOBSZ06
Good news and glad I changed my oil early.
Old Aug 24, 2015 | 02:59 PM
docf's Avatar
docf
Read this recently. This explanation plus the foaming issue due to sealants hopefully solves this problem. I guess the 16's will show us yay or nay.
To Reason for engine failure
