Official C7 Z06 Fast List - Provide all information and Slips/Video
#301
Ran in Roswell, NM - Alien City Dragway (3600' elevation) April 22, 2017
Stock with CAI, Nitto Invo tires (not drag radials). A8
Unfortunately they didn't have the 60' lights working.
#302
for stock on non stock tires, wfarmerz's post I can't access it https://www.corvetteforum.com/forums...post1591333091
wanna find out the tires he and #2 anti_venom used.
#304
What happened Tom the fast list?
Updated 4/7/16.
I'll probably need to look at uploading the original .xls file or convert it to .pdf and post so the links are active. Plus, I'm running out of screen room for a clip. Also need to add an internal mods category as there are two cammed cars on the list now.
S.
S.
Gearing up for the track now that spring is here. Anyone know what happened to the old list?
#305
Scraping the splitter.
And suggest you re-read the list before insinuating you were removed from it.
S.
#306
Hello S. my apologies. I found an updated list. My internet is slow out here in the Bering sea. Pages take for ever to load..
#307
for "Stock M7 (no Mods) with Drag Radials "
I only see 1 on the list, searched for "M7" no result too short of word, searched for "manual" that didn't really workout either. Does anyone know the next 3,4 down for it?
#308
Received 2,382 Likes
Is there no way to just update the first post in the thread so we don't have to click and scroll to find the current list? If TripleBlack has disappeared can a mod not edit the thread to allow Snorman to be the first post that he can update? The other Gen fast lists are like that and it's nice.
#309
10.56 A8 mechanically stock except headers
stanger383 | 2016 | 1/4 E.T. 10.566| 1/4 MPH 132.54| 60' 1.640| 330' 4.527 | 1/8th E.T.60863 | 1/8th MPH 105.63 | 1000' 8.867| Transmission A8| Tires hoosier quick time DR | Mods: headers |
the car is totally stock with the exception of headers. Stock tune as well.
#310
I believe sticky tires (DR) are considered a "Mod" that is why those times are not listed with "stock". Also light weight aftermarket wheels like front skinnies I believe fall into the mod category too.
#311
Do you have a CEL and P0430 cat inefficiency code from the headers?
#312
I have tinted windows that I did not list though
#313
The reason I think that is because 3 runs were made in the tour setting with TC button hit once. On the last run I was in race setting with TC off and it was by far a much better run. The only other difference was a decent cool down which I attribute most of the gain to.
10.81 off the street
10.79 hot lapped immediately after run 1(not even taking helmet off or turning car off)
10.75 cooled down 20 mins
10.56 cooled close to an hour and track mode
all 60s were within about .02 so traction was not the difference.
Also the MPH was consistent on the first 3 runs and gained 2.5 MPH on the last run
Norm
tail_lights (05-23-2017)
#314
I ran the car 2 days ago with no changes from the ladt time out and ran almost exactly the same times. Just a slightly better 10.55 and a 10.57. At this point I'm almost certain that the shift RPMs are elevated in the race suspension setting compared to the tour setting. I did not log any runs as of yet only because I have no intention of doing any tuning changes as of now.
tail_lights (06-09-2017)
#316
Heres my videos of the 9.87 pass, burnout, etc.
Traction off, track mode, 2,000 rpm launch
https://www.corvetteforum.com/forums...ith-video.html
https://www.corvetteforum.com/forums...0-5-7-sec.html
#317
great pass
Congrats on your performance.
#318
#319
This is the hardest fast list to follow ...
Can the main thread be updated? If not a mod should start a new thread, link this one and keep the main thread updated. Where is the actually modded list with other power adders?
okaythen (06-23-2017)
#320
Z06
I made a small improvement on my PB 6/23/17 at Zmax Dragway Charlotte NC in hi ambient temp of 88 degrees and very humid. Had a good time none the less.
I'm #4. Slight improvement on my PB.<br/>10.45@133.46 @ Zmax Dragway 6/23/17<br/>88 degree ambient temp
Mods since last PB post. Cam, custom Comp Cams grind, Kook's headers 1 7/8's & off road pipe, no cats,into stock NPP muffs, both blower pulley's, Halltech CAI, 100 octane unleaded fuel,head gasket insurance, custom tune-PCM of NC, 50 shot of nitrous for intercooling due to short cool down times between rounds at the drag strip and to aid heat soak issues. Nitto NT05R DR 345-30-19's at 25psi. DeWitt's Z06 cooling "kit" radiator, larger EOC and supercharger cooling heat exchanger.
TOUR mode TC off only.
