Halltech?
Old Sep 9, 2015 | 10:03 PM
DRLC5's Avatar
DRLC5
Default Halltech?
Ordering tonight for my 16 model. Is there more than one filter? I do not want to tune at this time. So which filter do I need or does it come by default? Also any deals for forum members? Thanks for any input.
Old Sep 9, 2015 | 10:28 PM
lgodom's Avatar
lgodom
I believe the dry filter comes stock bit the oiled filter comes as an option. The oiled filter makes more HP, but I'd sacrifice a lot tle power for the better filtering of the dry one. The dry filter isn't supposed to require a tune.
Old Sep 9, 2015 | 11:00 PM
xp800's Avatar
xp800
The Stinger RZ (rotomolded plastic for Z06) comes with the "high flow" oiled filter. This is the NO TUNE version for the RZ intake that flows most and makes the most power. The synthetic (dry) filter is optional and also NO TUNE with a tad better filtering efficiency, but gives up just a bit on ultimate power (~6hp in the RZ).
The whole filter confusion came from the differences between the CKNZ (carbon fiber + Nomex) and the RZ (rotomolded plastic).
Originally the CKNZ was the only one available, and the oiled (high flow) filter was "tune recommended" and the dry (synthetic) was the "no tune" option for the CKNZ only.
When the RZ was introduced and reached its final iteration of internal geometry, the high flow (oiled) filter became the "no tune" option with the same peak gains as the CKNZ, and the synthetic filter was an option for those wanting the last little bit of filtration efficiency at the cost of a small bit of flow and peak gains.
Jim has addressed this many times, but the misunderstanding for many obviously remains. I think his attempts at explaining the differences for the filters for the two different CAI models are not that clear because he pulls in too many dyno stories and evolutionary tales. (sorry Jim!) And the CKNZ (carbon Nomex) is NOT AVAILABLE any more until Jim can find another carbon fiber shop.
Cliff's Notes:
RZ + High Flow (oiled) filter = NO TUNE and MAX untuned gains
RZ + Synthetic Filter (dry) = NO TUNE and MAX filtration (and ~6hp less max gains)
https://www.corvetteforum.com/forums...post1590180274
Simple. The dry filter is more efficient in terms of filtration, at the cost of more restriction to flow, and less horsepower. Approximately 6 RWHP less than the high flow.
Tuning was required with our CKNZ intake when equipped with our high flow filter. The MAF read area of the carbon fiber intake was made to under-report airflow at the beginning (in prototype A configuration)
The wall thickness of the plastic intake can be controlled to allow any read area we want, and is our method of dialing in the air fuel ratio. LTFTs are dead nuts on with our plastic unit, and around +6 with the CKNZ. Moot point at this time, since we are not making the CKNZ until we find another carbon shop.
That will happen this fall.
https://www.corvetteforum.com/forums...post1590179250
All dyno reports so far have been with the high flow filter, both in the case of the CKNZ and Stinger-RZ.
The last dynos done on the dry filter was done on a different cars, but both the Gen 1 and Gen 2 were 44 and 46 RWHP respectively.
https://www.corvetteforum.com/forums...post1590177508
We have discontinued all carbon fiber products at this time. We will probably have the CKNZ back this fall.
The high flow filter has always been the filter that comes with the Stinger-RZ. All testing, dynos, etc. have been done with that filter. The dry filter is slightly more efficient at the cost of a few horsepower.
We will have a special going today on our website that offers the second filter for $49.00 when purchased along with the Stinger-RZ.
Old Sep 9, 2015 | 11:19 PM
oldfoggy's Avatar
oldfoggy
simple!
IT's great, lot of people have the proof . . . me too
Old Sep 10, 2015 | 06:15 AM
sammyv's Avatar
sammyv
xp600, Thank you for the explanation!
Old Sep 10, 2015 | 07:27 AM
DRLC5's Avatar
DRLC5
Great write up.
Old Sep 12, 2015 | 01:15 AM
CONMAX's Avatar
CONMAX
Mine came with the "no tune", high HP, oiled filter. That is shipped by default.
Old Sep 12, 2015 | 06:44 AM
Blvdbrawler's Avatar
Blvdbrawler
Love mine!
Old Sep 12, 2015 | 06:49 AM
DRLC5's Avatar
DRLC5
Who here has the Dry filter? Do all of you have the oiled filter? They only have dry filters in stock. Any real downfall or benefit with going dry over oiled? Thanks.
Old Sep 21, 2015 | 12:15 PM
badhabit_wb's Avatar
badhabit_wb
I bought both with mine. If you want to swap your dry for my oiled I will be glad to help you out. It hasn't been used.
Old Sep 23, 2015 | 07:51 PM
urslooow's Avatar
urslooow
My buddy got hall tech dyno showed 4 hp less than stock. I'm very cautious after reading all the posts about over leaning. Who better to say what air fuel level is best other than GM? I have no stake but want the real story.
Old Sep 24, 2015 | 02:29 AM
C7/Z06 Man's Avatar
C7/Z06 Man
WOW!!!
I have an A8 running the stock air intake that I added an aftermarket OEM replacement air filter to and all I could manage in August was a 10.68 with a 1.59 60 ft. on the OEM PSS tires. I hope to improve on that 60 ft.. I only had 1 real pass that day/night due to break downs, etc. at the track.
PS: What 1/4 mile ET's are the Halltech cars running? I think I may of seen "one" here. Post up.
EDIT: Times should start to improve now due to better weather.
Old Sep 24, 2015 | 06:13 AM
DRLC5's Avatar
DRLC5
Is this for real? There have been over 20 different results/threads from several different shops all with positive results and no issues, I have contacted 3 on my own with positive results just like the data shared on this site, And your buddy said he installed one and came in at 4hp less? Really?
Old Sep 24, 2015 | 07:44 AM
urslooow's Avatar
urslooow
Yes for real! If u r one of the ones who got a 40-50 hp dyno documented boost u should realize that it's not just better airflow. The MAF is in a different position and the ECU is "fooled" into delivering more power. GM sets a/f level in the 10s at WOT for a reason. If u don't know the reason maybe u should question the device or at least tune it and lose warranty
Old Sep 24, 2015 | 09:02 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Old Sep 24, 2015 | 09:44 AM
eric04's Avatar
eric04
Old Sep 24, 2015 | 10:40 AM
emericr's Avatar
emericr
Finally someone who dares bring some objectivity to the matter.
Dyno numbers can easily be manipulated. I will be a believer once drag strip racing same day with 2 Z06s (one stock and one with halltech) or roll racing.
DRLC5: Did I offend you in any way that you are ignoring my posts and pms?
To Halltech?
Old Sep 24, 2015 | 11:18 AM
punky's Avatar
punky
Banned Scam/Spammer
So a 10.7 1/4 mile is possible on factory tires and no mods?
Old Sep 24, 2015 | 02:02 PM
sam90lx's Avatar
sam90lx
Bingo! Dyno's CAN be manipulated.....love these, I got 700hp with an intake. Oh yeah....take it to the strip and get a time slip!
I had a Mustang on 3 different dynos....all different numbers, some as far as 25-30hp off on a little 302.
Old Sep 24, 2015 | 02:17 PM
HDLARRY's Avatar
HDLARRY
Dyno's can be very helpful if you don't pay so much attention to the top number as you do the difference of before and after numbers. This assumes all other conditions are the same.
I can't believe all the shops are massaging the before and after numbers but the MAF sensor location could make a difference. Only putting it on a dyno and recording the air fuel ratio along with other variables will give you an true picture of what is going on and if your in danger of hurting your engine without a tune.
