Whats the difference between the 2. I mean why choose one over the other? Does one have more hp gains than the other, or is one easier to install than the other? TIA.
Haltech does have a beautiful carbon fiber version available.
$1,000.00 difference in price between the two seems to be the difference I can see from reports posted herein. If there is only 2-4 HP difference between the two, and the difference is almost $1.000.00 more.....is that small amount of HP really worth that sum of money?
i sell both and install both. Shoot me a pm and i can go thru it all with you. They are great units also its not 1k difference. Its about 50 dollars differene between them on my normal pricing for plastic finish on halltech
They are actually the same price; the CF version of the Halltech was just released and accounts for that price.
Just bought the Afe from Norcal. $500 is a HUGE discount you may not see that often.
Afe is very user friendly to install, or remove, where there is no modifying involved whatsoever from what I have seen. I would hate to get the Ha;;tech, have a warranty issue and not be able to set things as they were to avoid any headaches that might occur.
You have to modify the coolant line on both the AFE and the halltech...
You guys making comments like these are ignorant on the install procedure for the Halltech. There is nothing to it and really no headaches setting things as they were....
To install you just shorten/cut several inches off one small rubber fuel line and lengthen another with a line provided with the Halltech kit.
To go back to stock you can leave the longer line as installed with the Halltech and buy a longer rubber line for under $5 at your local auto parts store to replace the one you cut. I'd have to look at mine but I think you can go back to OEM just using the line you cut.
Nope...not like me to be ignorant before making a decision. I watched just about every install video available before my decision. I also paid VERY close attention to where Halltech does not recommend anyone but a professional install because of the 'modifications that are necessary. I also looked at what people thought of the installation procedures historically and.....when all that is said and done, I chose Afe and enlisted my opinion why when someone asked...
Halltech: We highly recommend professional installation. The airbox is sealed, but is much larger than stock to promote better airflow, but it requires moving some of the engine bay components, and some modification.
I have installed both, and the install was almost identical, and both were installed in less than 45 minutes.
When they first came out the AFE drastically leaned out the A/F ratio, the Halltech, not so much. With the first units, using the data on AFE's website, I would not put one on without tuning. But both showed similar gains.
Recently, Diablosport tested the AFE and it did not affect the A/F as much. Must have been a running change. I don't know if the change affected the final HP gains.
Afe came out wuth a retooled box after the first group buy. -1 is new part number
I have the new -1 Afe. Wish I would of got it from NORCAL and saved some money. But I did get the Corsa X from him. Point is, my car was the one that Diablo used to tune with the new AFE intake and the A/F was pretty much spot on with the stock tune. So whatever changes AFE made worked.
Good. But with the changes made so it reads the A/F correctly, does it produce the same HP gains as when it read lean?
Shark, what other mods did you perform? How do you like the Diablo tune?
I only have 6800 miles on my Z and it was at the dealer for over 6 weeks for a phantom electrical issue they could not find until 6 weeks later. The General did right by me and made a monthly payment for me.
I have the mod bug again and want to research all options before I jump in!
My goal is 750-800 rwhp, but daily driving streetability and NOT breaking motors, trannies, parts and stuff are my main concern. Factory warranty will be out the door so keeping the boost and tune conservative will be key.
Anyways, let me know what you have done and if you have any dyno #'s.
Thanks,
-Ron in SoCal
I had 1100 miles on it with about 200 having the AFE installed. Only other mod is the Fasterproms Expansion tank. Car feels really good. The car was not lean with the AFE intake so not much picked up peak HP and TQ wise. But the throttle response is great and it drives really nice. Tried to go to the track last Wednesday but it got rained out. Here are the results and dyno chart on the last page.
Thanks,
-Ron in SoCal
I set up a car down in San diego with all the parts and made 732. Are you ok with e85 or only 91 pump?
AFE currently claims about 46 hp for their intake with their highest flow filter. Not sure what they claimed before the -1 modification was released.
Diablo dyno'ed Sharkgray's Z to be about 40 hp above stock with the AFE installed which is pretty close to AFE's claim. Not sure if Sharkgray had the lower restriction oiled filter. If not that could account for the 6 hp difference. Regardless 6hp is within normal variance for these test.
To clarify Sharkgray's comments in his last post. Diablo didn't find much additional power by tuning for the AFE vs the stock tune and the AFE. They did gain some mid range tq but practically nothing for hp.
Diablo verified they did in fact try to lean out the afr further than the AFE does on its own but didn't gain much by doing so.
This confirmed the AFE system was pretty much at the limit of what one can expect from a CAI.
That's good, I'm glad AFE made the -1 CAI a better unit.
