Wind Noise
Old Dec 31, 2020 | 12:16 AM
Thomasmoto's Avatar
Thomasmoto
Is it just noise or is rain/water coming in as well?
Old Sep 30, 2021 | 06:20 PM
Skid Row Joe's Avatar
Skid Row Joe
Originally Posted by Maximizer
Just paid $350 to get my vert creaking stopped by having all the bolts replaced with larger torque bolts per the TSB out for this issue.
What MY is your C7 vert? Which Chevy dealer did you take it to?
Mine's a 2017 that still creaks. The TSB for bolts didn't cover 2017s. The Service Manager said he couldn't do a TSB warranty on my creaking top because it wasn't covered. I said; it still creaks. Impasse. He promised to take care of it at NC even out of warranty
Originally Posted by davepl
Conversely, now that I have the convertible, I'll never buy a non-track coupe again.
My 'vert has no wind noise (by which I mean leaks) and at cruise you hear the tires more than wind, so I don't think it's much louder than the coupe, really.
So if you have a leaky seal somewhere, you should get it fixed, as its not normal for these cars.
Zero wind noise on mine too.
The C7 vert is my first Corvette vert. I swore I would not buy another PITA roof panel or T-top coupe again. I picked a good one in the C7 to go with.
As an owner described the insulation factor of the convertible top. It is so quiet in the cabin. It's nothing short of awesome! The vert just looks much than the hatchback, and the lines are much better than the C6 vert's.
Old Dec 17, 2022 | 08:24 AM
flittlejr's Avatar
flittlejr
What would be TSB # for replacing volts with larger? Thanks Frank
Old Dec 19, 2022 | 04:23 PM
Carnac's Avatar
Carnac
Try using painters' tape (the wide blue or green stuff) over the area you suspect is leaking.
If it is your driver's side window, you will have to have someone put the tape on while you are inside. Make sure the area is nice and clean or it will not stick very well.
Then take for a drive and see if that fixes it - if the noise is gone (you can drive the same route again with the tape removed) then you know where the problem is.
If it is at the window seal area, then you will need a new seal. If could also be other edges around the windshield of side glass (sound travels and can be difficult to determine exactly where it is coming from).
Wind direction makes a big difference too.
I would not use duct tape - it leaves a hard to remove mess.
Jim
Old Dec 19, 2022 | 05:06 PM
C7.R 004's Avatar
C7.R 004
My 2016 vert top is quiet until I hit 165mph.
