Wind Noise
Old Dec 3, 2015 | 07:38 AM
apolo's Avatar
apolo
Default Wind Noise
Recently picked up my new Z convertible, couldn't be happier with the car except that I have wind noise coming when driving at speeds 55-75 with the top closed. Anyone else have a similar issue ? Noise is coming from the driver side. It's driving me nuts
Old Dec 3, 2015 | 08:44 AM
bjones7131's Avatar
bjones7131
following this post
Old Dec 3, 2015 | 09:09 AM
ElCid79's Avatar
ElCid79
I am not trying to be a jerk here, so please don't take it this way.
Do you mean the normal convertible wind noise? Or is this actually air getting into the car and whipping around?
Old Dec 3, 2015 | 09:11 AM
apolo's Avatar
apolo
Not at all.
I have wind noise coming in, it seems only to be coming from the driver side.. No wind whistle from the passenger side.
Old Dec 3, 2015 | 09:44 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
One of the many reasons I will never buy a Vert again.
The ragtop is that, cloth you hear wind, surrounding noises, and other cars' tire noise.
Coupes all the way.
Old Dec 3, 2015 | 10:02 AM
Kyle Lemish's Avatar
Kyle Lemish
I have the same thing, just think its normal for a convertible car of any make, its actually less than my last Porsche turbo cab
Old Dec 3, 2015 | 10:33 AM
T-Z06-J's Avatar
T-Z06-J
I had the same issue but with a coupe.
I mentioned the wind noise from the drivers side to a co-worker and she pointed out the fact that the drivers side window seal looked different from the passengers side. (The deal was separated near the end)
I put tape over the seal and the noise was gone. I took the car to the dealer and they replaced the seal...
No more wind noise!
I don't know what the convertible is like but take a look at the seal near the window.
Old Dec 3, 2015 | 10:40 AM
mdz06vetter's Avatar
mdz06vetter
St. Jude Donor '05-'10-'11-'12-'13-'14-'15
No more wind noise!
Agree - sounds like seal issue
Old Dec 3, 2015 | 10:50 AM
Colonel's Avatar
Colonel
I'd take it to the dealer. Mine doesn't do that. Just normal convertible wind noise, exhaust, and tire noises. Seems to be sealed up pretty tight.
Old Dec 3, 2015 | 11:00 AM
Arctic Blastoff's Avatar
Arctic Blastoff
Mine was the drivers seal,it was coming out an looked slightly warped until i worked into place.It would make a "flapping" sound that drove me nuts.
Old Dec 3, 2015 | 11:30 AM
ElCid79's Avatar
ElCid79
That was my assumption as well.
Old Dec 3, 2015 | 02:43 PM
Kingspoke's Avatar
Kingspoke
I never had that problem with my 427, and I agree with most (above) that it is probably the driver's window not sealing properly. Should be an easy fix.
Old Dec 10, 2015 | 12:23 AM
Tunerz Store's Avatar
0Tunerz Store
Former Vendor
Same noise here from the day I picked it up from the museum on Friday. I suspect the seal on the driver side is defective, as it doesn't lay like the passenger side. Picture provide by member of stingray forum and after inspection my seal looks identical to this on driver side. Seems air would easily get around this back behind the panel, which explains why it sounds like the air is coming from the seat belt retraction area. Will have dealer correct this issue during break-in oil change.
Old Dec 10, 2015 | 01:17 AM
T-Z06-J's Avatar
T-Z06-J
Yep, that's exactly what mine looked like before it was replaced.
Old Dec 10, 2015 | 01:36 AM
h3mpking's Avatar
h3mpking
I thought my C7Z convertible was actually pretty quiet. GM did a good job with the top. It's triple layer insulated I believe.
Old Dec 10, 2015 | 01:56 AM
Lrn2Swm's Avatar
Lrn2Swm
No noise in mine. I hope it gets resolved for you.
Old Dec 10, 2015 | 08:54 AM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
To Wind Noise
Old Dec 10, 2015 | 12:34 PM
davepl's Avatar
davepl
Coupes all the way.
Conversely, now that I have the convertible, I'll never buy a non-track coupe again.
My 'vert has no wind noise (by which I mean leaks) and at cruise you hear the tires more than wind, so I don't think it's much louder than the coupe, really.
So if you have a leaky seal somewhere, you should get it fixed, as its not normal for these cars.
Old Jul 6, 2020 | 11:10 AM
TigerNine's Avatar
TigerNine
Cruising
Default Had the same issue
I had the same wind noise with my new 2016 Stingray coupe. I took it to the dealer and they fixed the seal issue under warranty. Best wishes!
Old Dec 30, 2020 | 07:20 PM
Maximizer's Avatar
Maximizer
5th Gear
Just paid $350 to get my vert creaking stopped by having all the bolts replaced with larger torque bolts per the TSB out for this issue.
