-RELEASE- LG Motorsports C7Z 1 7/8" Super Pro Headers
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
LG Motorsports C7Z Super Pro Headers
THE MOST POWERFUL CORVETTE HEADERS ON THE PLANET
The latest technology in long tube header design from LG Motorsports is now available for your C7 or C7Z06! If you are looking for absolutely the best exhaust for your C7 Corvette, the Super Pro headers are it.
The Torque Monsters of the Corvette World - No Corvette Header Has More TORQUE or HORSEPOWER!
All stainless steel mandrel bent construction using 304 stainless alloy. These headers feature a 1 7/8 primary design that will push your new LT1 or LT4 to higher torque numbers than the competition!
Full 3-inch x-pipe included NEW! True race-style 3-inch merge collectors for better scavenging. Available 3-inch premium high performance metal matrix catalytic converters (no converter flows more) Included "off road" pipes for track use. Race proven design makes more low end torque than any other brand, allowing you to have more of your engine's power on hand at low RPM while still producing fantastic peak horsepower. These headers have been tested on independent dynos by outside experts and show proven increased horsepower and torque over other top brands.
- Includes 02 extension wires
- Includes new GM gaskets
- Larger 1 7/8 primary designed for supercharged applications
- Includes 5 02 bungs. 4 OEM, and one for a wide band sensor
- High flow siamese style X pipe
- OEM hangers
- Limited life time warranty for original owner
- Bolt on install
- Slip fit design for easy install and smooth flowing exhaust
- LG famous merge collector with fire cone
Easy bolt on installation and no ground clearance issues
Don't just take our word for it, independent shops results below!
C7Z06 A8 before and after at Quality Motorsports
Install at Southwest Speed
NOW $100 OFF THROUGH NEW YEARS!!! MERRY CHRISTMAS!!!!
Tune required for headers? Price?
Former Vendor
Anyone telling you a tune is worth 20-30 hp either doesn't know better, or doesn't understand how radical temps effect these cars and is not making sure all temps (water and air) are close to the same when running the car back to back during changes.
If I do just the headers and cat what will happen to the CEL?
Second how much to install and can it be done same day with an appointment...ok that's three...rrm
Former Vendor
$700 installed and tuned + our headers (your choice of model)
Should be able to do same day as long as we have an appointment to do so. Hit me up for details and openings.
