Who's done E-85 conversion?
Old Dec 19, 2015 | 10:24 AM
Cordes Performance Racing's Avatar
Supporting Vendor
Originally Posted by Higgs Boson
Is that E85 and meth or just E85 without meth?
I have your dual lift pump setup in my C7, LT4 injectors, rails, and HPFP and the injectors are no where near being able to support the fuel needs even on E30..... ~850rwhp
I have an Alky Control Kit on the way to help supplement the injectors until someone makes bigger DI injectors.
We have made 841 rwhp through an auto on stock c7 injectors, single alky nozzle, Z hpfp, our fuel system. With Z injectors I've made 900 so far no meth looks like it would go a little more just haven't turned it up yet. On 100% e85 both scenarios, I have other variations too making different power levels but these two are most relevant to the discussion.
Old Dec 19, 2015 | 11:01 AM
sr71bb's Avatar
sr71bb
Default C7 and E85
There are some issues related specifically to fuel delivery on a C7 that makes E85 not really a viable option when you are talking about pushing the envelope on HP on a C7, at least currently.....
Example: AMP with an F1X was able to push BOOSTEDTV's C7 Z06corvette to over a 1000 RWHP on boost only but with the STOCK fuel system. That SAME F1X on White Lightnings C6 corvette makes over 1400 RWHP using of course an AFTERMARKET fuel system.
Since you have to push 30-35% more fuel to an engine if you use E85, it makes the fuel delivery issues even more problematic at the higher HP levels. So if more octane is needed, the current solution is to use race gas NOT E85 on a C7.
It is just a matter of time of course before vendors start coming up with a better fuel system for the C7's but they will have to be designed to be E85 friendly. GM has done some pretty tricky things with the ECMs on the LT4's and LT1's so it makes it more difficult to tune and to integrate aftermarket products to a certain extent.
On a personal note, my F1R Camaro did about 7 MPG on E85 compared to about 11 MPG on 93 on my LS3 so I was seeing MORE than a 30% decrease in mileage. Of course I didn't really give a **** since it made over a 1000 RWHP LOL. The LT1 and LT4 technology with direct injection is much more efficient though so I would suspect the gas mileage there to be MUCH better.
Old Dec 19, 2015 | 12:06 PM
Higgs Boson's Avatar
Higgs Boson
just making sure you were using alky too, which is what I will have to do also. the DI injectors are not big enough to support that power without meth as a fuel source.
confirming I am not crazy!
Old Dec 19, 2015 | 12:12 PM
Higgs Boson
The issue with the DI is that you can't begin spraying fuel until the exhaust valve closes. This leaves close to half the time to inject fuel vs a port injected motor. There is not enough time to get all the needed fuel in before the spark plug fires, of course with ethanol the problem is exacerbated.
This is why all the bigger power setups use meth. Not just to cool the charge but to add more fuel....
Old Dec 19, 2015 | 01:22 PM
davepl's Avatar
davepl
Originally Posted by sycraft
The stock fuel system can handle it with no issues, the components are compliant as per standard for E85. many of the components are used in flex fuel trucks. Mine is done, works great, keeps tips cleaner longer and the 30 plus HP gain is a nice addition. plus 20 bucks to fill up....
Except the chief engineer specifically said that the fuel pumps can't keep up, and that to do E85 would have required twin in-tank pumps and a bigger mechanical pump, all at extra cost, so they decided not to.
So to come in here and just say "it can handle it", that's crazy. Yeah, at idle, an at 80% max output, sure. But at peak torque you're rolling the dice. And they're some expensive dice to roll.
Note that Joe@CPR and similar are adding extra fuel delivery (though not sure about the in-tank portion).
Old Dec 19, 2015 | 01:27 PM
Higgs Boson
CPR offers an extra tank pump (lift pump) that I have on my car. With it, there is no fuel supply issue to the HPFP at the motor even on E85. Without it, yes, the fuel pressure tanks. The C7 and C7Z use the same in tank pump. As of right now, a second pump is the only solution.
Commanding more HPFP rail pressure also makes your injector "bigger" and even commanding 24 Mpa (C7 is 15 and C7Z is 20) the LT4 injectors are still the weak link simply due to injection time.
Old Dec 19, 2015 | 02:01 PM
johnglenntwo's Avatar
johnglenntwo
Default Oops! Got to recant!
(Note: All the tuning was performed on E85 fuel with a 57 percent mixture.)
Read more: http://gmauthority.com/blog/2015/08/...#ixzz3unJY4Xia
32% fuel lobe; I thought this worked out
https://www.corvetteforum.com/forums...and-video.html
Old Dec 19, 2015 | 07:05 PM
T/A KID's Avatar
T/A KID
I don't care what a "chief engineer" says... You can do about 700rwhp with the factory lt4 fuel system on around E60
Old Dec 19, 2015 | 07:19 PM
johnglenntwo
Default 57% is about E60!
And Tadge never said you couldn't!
They sell E85 therefore the car needs to be able to run that worst case, simply engineering 101.
Old Dec 20, 2015 | 09:18 AM
Busa Dave's Avatar
Busa Dave
AMP is doing my car now--parts are being ordered and others sent to machine shops. The E85 will net a little more but you are correct that the factory fuel delivery system can only be modified so much.
Old Sep 14, 2017 | 10:50 PM
prince8619's Avatar
prince8619
I know it an older thread and I've been having a hard time finding more info online.
Right now I'm running an A&A setup SC. Dynoed at 550 rwhp. Only pushing 5.14 lbs. (Conservative tune) I was thinking about doing the E85 flex fuel kit since in Colorado many gas stations have it. My goal was to go full E85 just without upgrading the fuel system. I keep seeing mixed opinions..some say the stock FS can handle it, others say it can't. My goal is 650 to 680rwhp. Would it work?
Old Sep 14, 2017 | 11:56 PM
johnglenntwo
Default Auxillary radiator - 100oct tune - Warranty!?
http://www.superchevy.com/how-to/add...5-fuel-switch/
For 15 - 20 degrees?
Old Sep 15, 2017 | 08:12 AM
  #33
h3mpking's Avatar
h3mpking
Supplemental port injection with the larger power Procharged builds seem like the way to go now. Run straight E85 without the demand for meth.
Old Sep 15, 2017 | 10:19 AM
  #34
TXRR's Avatar
TXRR
I run e85 no problems.
Old Sep 15, 2017 | 11:36 AM
  #35
ZoratZ06's Avatar
ZoratZ06
What is required to run E85 on a stock C7Z? Will it void the warranty? Does it require a tune etc?? Thanks...
Old Sep 15, 2017 | 11:40 AM
  #36
mike123460's Avatar
mike123460
You will need the flex fuel sensor (400$). Yes you're going to need a tune. Most people do meth at the same time, they benefit one another nicely and produce nice gains for the cost. I recommend it.
Old Sep 15, 2017 | 11:44 AM
  #37
Billy@MTI's Avatar
0Billy@MTI
Former Vendor
We do this a lot!!
