Bleeding Clutch Fluid
Old Dec 29, 2015 | 02:07 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Originally Posted by b4i4getit
If a dealer does the Ranger method and charges you for a full flush you have more significant issues with that dealer. He probably does not change the oil filter either. Bad dealer. The problem is the sludge that remains in the slave. It does not travel in the reverse direction up into the reservoir. Think of your toilet. No matter how many times you flush the material in the bowl will not end up in the water tank. Its not an exact analogy but you will see what I mean. As for you guys that continue to swear by the Ranger method go ahead and keep doing it if it makes you feel better. Its your car. I am just trying to dispel the bad information that this method is just as good as a real fluid flush. It is not and never will be.
Nobody said it is as good as a full flush, but to say it is only cosmetic is a fallacy. Go watch the Ranger video and come back and comment on what is untrue.
