Active Rev Match question
Old Jan 25, 2016 | 12:23 AM
Sunny_M3's Avatar
Sunny_M3
Default Active Rev Match question
Hey there my fellow Z06 owners, when using active rev match, I notice that it takes a little dipping into the throttle to extract power whereas with non-active rev match, the throttle is more responsive and doesn't require as much effort.
Is this normal given that engine speed has to be matched on down shifts and therefore a little more throttle application is required?
Any and all advice/thought would be helpful.
Thanks everyone
Old Jan 25, 2016 | 02:32 AM
Bill Dearborn's Avatar
Bill Dearborn
Haven't noticed any such problem. Haven't used it on track yet but when trying it out on the back road near my home I didn't notice any throttle lag after making my turn in and moving over to the throttle as I drove by the apex. Throttle felt the same whether or not I was using ARM.
Bill
Old Jan 25, 2016 | 02:42 AM
WaFp's Avatar
WaFp
Used the Rev Match on the track, road and strip (for no-lift-shift), and it worked for me as advertised. The "trick" is to downshift like it's a race. And by that I mean don't waste time clutching in and out. The computer "blips" the engine as you push the shifter into gear, but it's only at that point that the tranny and engine revs match. The longer you wait the more "off" the revs will be.
Old Jan 25, 2016 | 05:54 AM
Gomer's Avatar
Gomer
Are you saying to not use the clutch at all when ARM is engaged?
Old Jan 25, 2016 | 06:33 AM
Babaron's Avatar
Babaron
Worked fine for me both on and off Track with no perceived difference.
Old Jan 25, 2016 | 06:35 AM
Babaron's Avatar
Babaron
I think he's saying use the clutch but shift quickly and smoothly with no delay or hesitation.
Old Jan 25, 2016 | 07:57 AM
Fastmikefree's Avatar
Fastmikefree
No difference for me either. Works perfectly and love that sound!!! :-)
Old Jan 25, 2016 | 08:34 AM
6104696's Avatar
6104696
no difference for me. I am ashamed to admit that it took me almost a month to realize that the gear indicator turned yellow when ARM was activated...........
Old Jan 25, 2016 | 02:32 PM
VictorBarron's Avatar
VictorBarron
Old Jan 26, 2016 | 12:21 AM
WaFp's Avatar
WaFp
Correct. Clutch in/out as quick as possible. The "Pure F'n Magic" (aka computers) will be able to keep up with our slow human reactions
To Active Rev Match question
