So far, I'm digging the Z06. Wowzers.
Quick question tho. Does anyone else have any rpm rev increase off throttle?
For example. If I'm just cruising at low speeds. If I blip the throttle the car obviously reacts and accelerates, but once I'm off throttle, it still seems to rev out for a second and car seems to lunge forward even off throttle. It's just a quick second blip of increases rpms when I'm off throttle. Kind of strange.
So, it's a quick on and off throttle, but the rpms' still want to rev up once I'm off throttle. So, I'm finding myself having to tap the brake a little bit. Most cars I've ever own, once you are off throttle the revs obviously decrease as soon as you are off throttle. It doesn't happen all of the time, so I'm just wondering if I'm in between some kind of rev match or something. Who knows.
It might be a stupid question, but as I get to know the car, I'm noticing things.
Yes, has happened to me too. have read where it has happened to others also. New learning curve.
Yea, that's what I was thinking. Just one of those things I have to learn. It's not alarming like anything is wrong, just a small thing I noticed that was unlike any other car I've driven.
If you are in Sport or Track mode the car is trying to keep you in that power band because it thinks you are on a track. If you are in Touring mode and it is happening then it is not normal.
Exactly what I was going to say
Is it an A8? You might have blipped it enough that it goes into performance mode. If it just so happens that if it goes into performance mode when you are ready to slow down, it does feel like and actually is a lunge.
i have encountered this many times since september, and every time i think, at minimum this is unsettling, and even feels a bit unsafe. Every time i am surprised the engineers would let that happen. I will keep track of what mode it happens in. It doesnt happen quite so much and severe that it makes me dislike the car. It is manageable at this level. If it were twice as bad or more than twice as bad, it would probably start to affect my enjoyment of the car. Its probably the one thing that makes me miss my c6z. The control of the power with that car was very precise in comparison to this one. Probably due to the a8, which is expected, but this surging thing took me by surprise. I still wouldnt choose the stick as a daily driver though, did that for 10 years with the c6z, and its just too tedious. For a track only car i would choose a stick though for the much better power control.
If you have a M7 I don't think it is normal at all. Never experienced that phenomenon. Sounds more like something that might happen with an automatic transmission. What transmission do you have?
Knowledge is power. Thank you sir. I'm always in Sport. See, now I know the reason. I have an A8.
Anyhow that has been my experience.
Yea, that's another thing. The performance mode in Auto mode. I like it cus it revs down gears fast with almost no lag, but then it can't predict a false rev either and keeps rpm's up even if I'm not really racing. I think you can hit the paddle and it overrides it. Anyhow, I'm learning the car as I drive it more.
I didn't notice it at first even when others reported it. But having driven the car for 17,000 miles now it is definitely there.
I'm 99% sure it's just the inertia of a belt driven supercharger. It doesn't happen off boost which leads many to believe it's not happening with their car. This was certainly the case for me when I was breaking-in the car.
There may or may not be a solution for this behavior. I've read an article where the Dodge team have a bypass specifically to eliminate this behavior.
Anyone have a Hellcat and a Z and is willing to let off the gas at full boost and observe the throttle input decay rate?
"From the standpoint of driveability and durability, Hellcat has two other interesting features. An electronically controlled internal bypass valve located between the inlet side and the discharge side of the compressor allows air to move directly into the intake ports without being compressed. Under low load and off-throttle conditions, it lowers parasitic drag on the engine and reduces wear on the compressor. The other feature is a decoupler—a one-way mechanical diode—inside the supercharger pulley, which only allows torque to be transmitted in one direction. The compressor's rotors are then allowed to freewheel when engine speed suddenly drops, during shifts for instance, thus saving unnecessary wear on the compressor's geardrive and preventing problematic drivebelt dynamics."
See? The Z has the bypass but I don't think it has a decoupler. The decoupler sounds like it would eliminate the inertia of the rotors when the rpms drop when you take your foot off the gas.
My E55 Mercedes and my Harley Truck, both supercharged and automatic transmission vehicles seemed to have power surges after you had just rolled out of the throttle, particularly coming out of a burnout.
Yes, you are correct your car does not have a fault per se. I believe all C7 Z's have this behavior.
My Stingray did it as well as my Z06. pretty sure it isn't boost related though possibly worse on the Z06.
It comes from the way the torque delivery is programmed in the PCM.
There will always be a lag between requested torque, commanded torque and lastly delivered torque. This delay is probably only a couple of thousandths of a second maybe less but it is there.
I believe the surge we feel happens after you close the throttle completely (0 torque requested and 0 torque commanded) and when the PCM commands idle torque (around 5-7%).
If you are quick enough to get completely off the throttle and then barley back on it (roughly 8-10% throttle opening) you will notice the surge never comes in. Release completely and stay off of the accelerator and the surge is always there. (at least in the M7 Stingray and Z06 anyway.)
Interesting. Then we're looking at implementation of the drive by wire. I'm not a fan.
