Pop when turning wheel
Mine does the "popping" as well. It is not the tire chatter when turning at full lock. This feels like it's in the steering? It will pop in different directions and either going forward or backwards while barely turning the wheel.
Mine just started making that pop noise, too. I know what the rearend chatter and the front tire noise sounds like and this is neither. Mine does it more often backing up, but occasionally at small turns going forward. I'd love to hear the cause before I take it to an inept dealer where they'll scratch their heads for a while. It doesn't do it all the time which would make it even more difficult to diagnose.
I really would like to know exactly what part of the front suspension is "popping."
Perhaps it is normal and nothing to worry about, but I want a detailed explanation I can live with (sorry for being a pain-in-the-rear, guys).
After 650 miles I am finally starting to open it up and drive it hard.
I sure the heck want to be confident of the front end holding together when I push.
It's the tire skipping. The tire is literally almost coming off the ground and the force that was in place before it skips will cause your steering to smack.
If you really think something is wrong with the steering, you would definitely feel it at speed.
It's the front tires rolling contact patches binding up in a tight radius turn, then releasing as the bind up suddenly slips, creating the popping and jolting sensation. Think of it as somewhat analogous to tectonic plate movements storing and releasing energy
It'll usually only do it once or twice. Very odd. Never felt anything like it. I never use the parking brake. It feels like it's in the steering. Only happens at very low speeds. Def not turning the wheels anywhere near full lock
#35
does it feel like it's in the column? Again there are so many things this could be. Probably best to go to shop.
#36
#37
Hey guys, for those of you that are getting this "popping" noise, have you lowered your car? I lowered mine all the way down on the stock bolts and I'm wondering if this could have anything to do with it?
#39
Originally Posted by Arctic Blastoff
yup its lowered all the way down
