Cat Delete Kit, 02 Sensor Simulators
Old Nov 12, 2016 | 08:38 PM
NinjaZX14r's Avatar
NinjaZX14r
Default Cat Delete Kit, 02 Sensor Simulators
FR.Sport, Blox Racing CEL Fix each unit about $4.80, Part Number BXFL-00108.
Each pipe will require two of these units, stainless steel..no rusting easy install.
NW
Old Jun 11, 2017 | 11:37 PM
Sk8Man_'s Avatar
Sk8Man_
Each pipe will require two of these units, stainless steel..no rusting easy install.NW
How have these worked out for you? Any additional modifications needed since?
_
Old Jun 11, 2017 | 11:43 PM
NinjaZX14r's Avatar
NinjaZX14r
Default They do not work.
_
Tried two different straight stainless sets up front. Cel light immediately.
Some members using 90 degree units and having some luck already spent $150.00 on current sets that did not work so hesitate to spend another $100.00 for the 90 degree units.
some members welding the bung holes completely closed having some luck.
It is a crap shoot.
NW
Old Jun 13, 2017 | 06:00 PM
dvandentop's Avatar
dvandentop
how many miles have you put on with these?
Old Jun 14, 2017 | 08:26 AM
wagoetzmann's Avatar
wagoetzmann
Someone correct me if I am wrong but I believe you only need to put the CEL fix devices on the "rear" O2 sensors....if you put them on the "front" the ECM will not be happy.
I removed my main cats and used Big Daddie's Garage Mini-Cat (straight with cat material) on the rear O2 sensors with no issues, no CEL.
Old Jun 14, 2017 | 08:39 AM
onfire's Avatar
onfire
You are correct. Rear o2's only. With the factory mufflers, how loud is wot with the front cats gone ? I don't mind some sound, but not that nasty raspy cut your muffler off sound.
To Cat Delete Kit, 02 Sensor Simulators
