Sponsored by: GEM Motorsports
Ramps vs lift
Old 12-18-2016, 06:59 PM
  #101
tracer3030
tracer3030's Avatar
I did buy the BL 3500 with a DC pump so I can take it to the track and just use a jump pack to run it. The quality of it looks good welds look ok. Comes with rubber blocks to lift. I will use jack pucks and the blocks. They did send me the BL 5000 First so I got to take a look at both. The BL 5000 is the way to go if you’re going to use it in the garage at home. Wide longer taller heavy duty compared to the BL 3500. I wanted the lighter 3500 to haul around with me in the trailer. I think theres a Xmas sale going on just call I got a smoking deal on black friday sale! I have a 4 post hoist in my garage.3500 will work for what I want but I would suggest the 5000 for the C7vette
Old 12-18-2016, 07:04 PM
  #102
Larry M
Larry M's Avatar
Calling this week
Hoping for a smoking hot deal!
Going for the 5000
Old 12-18-2016, 07:40 PM
  #103
BAAD LS2
BAAD LS2's Avatar
2018 Corvette of the Year Finalist
2017 C6 of Year
What do you mean by smoking deal? They have $100 off right now with Santa100 promo code. I'll be ordering this week as well, but if there is better than $100 off let us know!!
Old 12-18-2016, 07:47 PM
  #104
tracer3030
tracer3030's Avatar
Black Friday deal was $150 off the 5000. They did give that same deal to me on the 3500 with free shipping. I did call in and ask whats the best deal on BLK Friday week. Call in and ask for Ryan Delapp or use this # 1-805-933-9970 Ext 124 maybe he can get you the best deal Tell him Tracey’s said to call him
BAAD LS2 (12-18-2016)
Old 12-18-2016, 08:28 PM
  #105
MassGT
MassGT's Avatar
Do you think you can install new side skirts with the Quick Jack?
Old 12-19-2016, 08:05 AM
  #106
Mordeth
Mordeth's Avatar
Received 1,678 Likes on 878 Posts
2018 C6 of Year Finalist
St. Jude Donor '10, '17
When I use mine, part of the lift is under the side skirts. So I don't think they could be removed/installed using it they way I am. If I move the blocks, I should be able to push the lift under the car farther and perhaps they would clear. I can test it next weekend if you want.
Old 12-19-2016, 05:01 PM
  #107
Larry M
Larry M's Avatar
Spoke to Ryan just a short while ago, he mentioned $100 off for Christmas and couldn't match the $150 off
I'll think about it
Old 12-24-2016, 10:18 PM
  #108
snomuncher
snomuncher's Avatar
Default Quickjack BL-7000 SLX Assembly
Discussion of assembly experience moved here:
https://www.corvetteforum.com/forums...post1593730546
Old 12-25-2016, 09:55 AM
  #109
Larry M
Larry M's Avatar
Great write up! Thank you! Also thank you for noting the epoxy scratching, that is a major concern of mine.
I keep carpet squares under my tires, do you think I could do the same for the quickjack and not scratch the floor?
Old 12-25-2016, 11:25 AM
  #110
snomuncher
snomuncher's Avatar
Default Quickjack
Larry:
I plan to use a thin carpet mat under the ramps in the future. I am also also thinking about buying thin indoor/outdoor carpet material (like I throw in the back of the pickup) and attaching strips to the bottom of the ramps with contact cement. Since I plan to use the Quickjack almost exclusively in the garage that would eliminate the scarring of the epoxy as I move the ramps under the cars.
Old 12-26-2016, 06:04 PM
  #111
k5ride
k5ride's Avatar
I bought a Direct 4 post lift for my garage about a year or so ago. It has made such a huge difference, I will never be without one again. It sells for just over $2000 but I ordered some extra options and had it delivered and set up for a total of around $3000. It is made by Rotary but under the Direct lift name. It is also safety approved and certified. All the stickers say Rotary. I can even roll it out in my driveway to pressure wash the underside of the corvette. I park one vette on the lift and my other under it and still have room to use the rest of the garage. It is an 8000 lb lift. Has casters, drip trays and sliding jack tray included. For about $500 more, you get a sliding jack.
http://www.directlift.com/Four-Post-...ard-P44C9.aspx
Old 12-27-2016, 01:31 PM
  #112
JC 2004
JC 2004's Avatar
Looks nice!
k5ride (12-27-2016)
Old 01-10-2017, 09:40 AM
  #113
PDCjonny
PDCjonny's Avatar
Storage footprint for QuickJack 5000. Zero.
Old 01-10-2017, 09:41 PM
  #114
Larry M
Larry M's Avatar
Nice idea, I assembled mine on Sunday. Instructions were ok, the black and white photos were very difficult to see
Old 01-11-2017, 06:26 AM
  #115
PDCjonny
PDCjonny's Avatar
Plenty of YouTube videos on the use and assembly for reference if you get stuck.
Old 01-11-2017, 07:36 AM
  #116
Larry M
Larry M's Avatar
Yeah it was pretty simple, certainly go through it.
Even though pictures and videos make them look light, these things are pretty damn heavy.
Definitely need some type of carpet underneath if you have a nice floor coating
Old 01-22-2017, 10:23 AM
  #117
Larry M
Larry M's Avatar
Finally got mine assembled and put to use.
A few notes:
These things are really heavy, while I'm not a body builder, I'm not exactly weak.
I highly recommend a carpet underneath, they slide much easier for proper positioning and gives you something to lay under. Also protects your floor coating if you have a floor coating. I bought carpet from Lowes for $0.45 a sq ft, for a total under $50
Easy to assemble, just a bit of a pain in the rear.
Transmission fluid (need to buy 2 quarts) is awful smelling
While they don't look strong, once you receive them you're kinda blown away and those thoughts are long gone.
Unfortunately I had 1 quick disconnect leak, they're very heavy duty but one leaks so I'll have to reach out to Ranger to send a new one
Their instructions are not the greatest, the pictures are black and white and really hard to see any details, but as I said it's easy assembly. Also note, one of the wrenches they tell you to use is 1 size too small.
Overall, I'm extremely happy, simple operation with very strong parts and a very tall lift. Where were these when I installed headers!!!
To Ramps vs lift
Old 01-22-2017, 01:18 PM
  #118
c7neb
c7neb's Avatar
Originally Posted by ZR1North
Hi All;
I don't have the option to install a two or four-post lift in my current garage setup. I am considering the system below as an alternative for small jobs like detailing, oil changes, etc (not tranny pulls or things of that sort). Has anyone had experience with this modular system?
https://raceramps.com/car-ramps/gara...l-length-lift/
I bought the 80" Combo RaceRamps for my wife's car and can use them on my 2014. They are easy to store in an attic and come in two pieces per ramp. They are very dense but light. I bought some auto show "demos" so the price was reduced.
Old 01-22-2017, 05:23 PM
  #119
PDCjonny
PDCjonny's Avatar
Not being able to pull the wheels off makes it a non starter for me.
Old 01-22-2017, 08:05 PM
  #120
fasred01
fasred01's Avatar
Originally Posted by Mordeth
Not a stupid question at all. I had the exact same question before I bought mine. As Jeff said above, it lifts at the jacking points.
It does not lift along the whole frame of the car, although it looks that way in pics. What happens is that they supply you with these rectangular, rubber blocks. There are a few sizes. They sit on top of the lift at 4 separate locations and can be moved around. These are the lift points.
So on a Vette, due to the fact that it is low and may have side skirts, you can also use jacking pucks. Using the pucks also makes sure that the rubber blocks don't touch the rockers. So the procedure is to install the pucks on the car, slide the lift under the car, then place the supplied rubber blocks on top of the lift and directly under where the pucks are. So basically the rubber blocks will lift exactly where the pucks are, onto the pucks. It can be done without the pucks as well if your car has enough room at the jacking points.
As far as I know, the ramps are generic and will likely work on most cars. They are rated according to weight. I have the 5000lb rated unit but they also make a 7000lb rated unit with an adapter for SUVs. I've used my lift on my Benz, both my Vettes (C6 and C7), my wife's Acura and my son's Nissan. All with no problem. Just locate the jacking points on the car, and arrange the rubber blocks to be below those points. I've used it with and without pucks.
Mordeth, Just to chime in... I have the quickjack 5000xl. I bought them shortly after buying my car and struggling to get all 4's up to change oil with a jack and jack stands. These are a great alternative. I don't use them often, but definitely every year at storage time to work on the wheels and clean under the car. As you stated these are very safe as long as you engage the locking bar and hit the down button to seat them. I don't have room for a post lift so these are great.
I think you have explain these very well several times. Well done !!
Quick Reply: Ramps vs lift
