Another boring Z06 intake+tune+E85 dyno thread
Old Nov 23, 2016 | 01:49 PM
Chalky's Avatar
Chalky
St. Jude Donor '08-'09-'10
Very informative.
Thanks.
Old Nov 23, 2016 | 05:30 PM
CFHay's Avatar
CFHay
Originally Posted by Terry Burger07
jbsblown has a Haltech on his so we'll do a similar test later when I help him with his tuning. I'm curious also. Based on my initial analysis though the result should be the same. Where the Haltech might shine is with a more stock like MAF scaling since it's more of a round tube/filter. So that would make tuning easier. But we'll see.
Looking forward to seeing some more real world results
Old Nov 23, 2016 | 05:33 PM
Taimur's Avatar
Taimur
Thanks Terry for this analysis. It is really helpful.
Only problem is that many people, including myself will not be tuning the car in fear of losing the warranty. The reason why intakes pick up more hp on stock tune is probably mostly due to leaner AFR due to higher airflow, as you've already stated. Since you've tuned your car now it's not losing as much power run after run and intake benefit is reduced.
I wonder how the '17 will react to intakes since it probably already has a more aggressive tune.
Old Nov 24, 2016 | 12:02 AM
Terry@BMS's Avatar
0Terry@BMS
Former Vendor
Just asked this on the HP Tuners forum but maybe someone here knows. Kicking myself for not finding and zering out this table while I had it strapped down. Next time! Is there a known issue with Cylinder 1 knocking or running hot?
Originally Posted by TerryBurger
Trying to track down a random midrange knock issue in my 2016 Z06 running E30 fuel. It's stock boost and stock timing down low so I did not expect much timing pull. Anyway I noticed the factory tune runs a static timing pull in cylinder 1. Could this just be what I'm seeing in logs? I'll zero out the table as a test next time I'm on the dyno to verify but hoping someone has come across this before.
Old Nov 24, 2016 | 12:04 AM
Terry@BMS's Avatar
0Terry@BMS
Former Vendor
Yes I hear you on wanting to lean out the AFR a bit without having to tune. The 2017 tuning from what I can see is identical except for less aggressive timing pull as a function of coolant and intake temperatures. No fueling changes I noticed.
Old Nov 24, 2016 | 01:20 PM
T/A KID's Avatar
T/A KID
cylinder 1 is not the problem, I would say cylinders 7 and 8 are due to manifold design... the 17 z06 fixes some of this to some extent
when scanning you need to view the spark table in a different format, your only scanning to 105kpa effectively not looking at spark in the boost Regions (factory car will be around 160kpa)
this is Ben C on hp tuners
Old Nov 24, 2016 | 01:27 PM
Terry@BMS's Avatar
0Terry@BMS
Former Vendor
This morning I zerod out the cyl1 built in retard and verified it's pulling clean now without much knock reported. Happy that is resolved. But I wonder why GM had it there? Is some sort of emissions system closer to cyl1 that needs to heat up? Shrug.
On the logging histogram display format you are right, it just lumps everything in the 105 row. I tried to change it to show spark airmass which is what the timing table is indexed on but after 2-3 min was not able to sort it. When I look at the logs on the dyno I normally scroll through the data points anyway. But I'll fix those histogram indexes soon as they should make tuning timing even easier.
Old Nov 24, 2016 | 01:57 PM
speedraider's Avatar
speedraider
Haha yes, same Terry Burger. In 2008 I started a company selling BMW tuning systems I designed and I've been doing that ever since. The Z06 is just a personal toy for fun. No plans to get back in to GM tuning other than helping friends, arguing on the forums, etc. I sold my C5s in 2005 when my wife got pregnant and I've been wanting another Vette ever since. The close out deals on 2016s were just too much for me to pass up. Plus, it makes a good race comparison car for all of our BMW tuning marketing.
I was wondering if this was the same Terry Burger that i bought a piggy back tune for my mercedes c250. Glad to see you here...
Old Nov 24, 2016 | 07:40 PM
Higgs Boson's Avatar
Higgs Boson
pm me your email and I'll send you my config file and make things easier on you.
Old Nov 24, 2016 | 08:05 PM
Terry@BMS's Avatar
0Terry@BMS
Former Vendor
Thanks!
Old Feb 5, 2017 | 11:23 AM
div7racer's Avatar
div7racer
Default Hi Terry
I am very interested in what you are doing. I have sent you a PM.
Ed
Old Feb 5, 2017 | 12:11 PM
Terry@BMS's Avatar
0Terry@BMS
Former Vendor
I disabled the PM system. But I am working on a new drop in style filter. Will post info when we have it. It's sort of a slow process.
Old Feb 5, 2017 | 12:36 PM
  #33
div7racer's Avatar
div7racer
Default would like to talk to you......
I would like to speak with you about the Z06 and % of ethanol.
I am in SoCal and drag race my car quite a bit.
Is there an email address or a preferred phone # and day/time I could call?
If you want to send me an email at Cp-Carrillo where I work my email is
eurcis@cp-carrillo.com . I am there M-F from 8-5 but will be at Pomona
this Thur through Sunday working at the Winternationals.
Ed
Old Feb 5, 2017 | 01:39 PM
  #34
Terry@BMS's Avatar
0Terry@BMS
Former Vendor
Just ask here, happy to answer any questions on the setup. E30 has been working great.
Old Feb 5, 2017 | 02:04 PM
  #35
div7racer's Avatar
div7racer
Default E30
Thanks Terry.
I installed the flex fuel sensor and the wire to the ECM on my own.
I took the car to "my guy" who told me he put in the tables for the ethanol. I then put in E35 fuel and we logged some runs.He was logging fuel rail pressure to see if E35 was safe. In 4th gear the power was nosing over, and the rail pressure was way below 2000 lbs.Next we tried E30 and it was still loosing power but had about 2200 lbs pressure.With E25 it runs great, and has around 2600 lbs. He had to remove a little bit of ignition timing for the E25 tune compared to the unleaded 100 octane tune I had used (I wanted to use an EXX fuel as it is a lot less expensive than the $9.00 a gallon unleaded I had tried).
I have a CAI, 10% lower supercharger pulley,and a 160* thermostat, all else stock.
Any ideas why I can't run over E25 fuel?
Ed
Old Feb 5, 2017 | 03:10 PM
  #36
Terry@BMS's Avatar
0Terry@BMS
Former Vendor
The fueling limit isn't anything I have experience with on this platform. Did you monitor low fuel pressure? Perhaps you have a weaker lower pressure pump or clogged filter?
Old Feb 5, 2017 | 03:33 PM
  #37
div7racer's Avatar
div7racer
I have asked some vendors and was told I need a better low pressure system, others say I need a camshaft with bigger fuel lobes and/or a modified fuel pump or a new ($1500.00) hi volume pump.Another says it is just a matter of proper tuning of the injector cycles and such (but maybe I will also need their modified fuel pump).
I have monitored the hi pressure fuel rail pressure, and the greater % ethanol I run the lower the fuel rail pressure. My Dodge Cummins also has a low and hi pressure side to the fuel system, and as long as the low side has at least something above 0 the hi pressure side will keep the proper amount of fuel rail pressure.I confirmed this scenario with a manufacture of racing fuel pumps and parts, and they say I should concentrate on the hi pressure side as long as the low pressure side has something like 1/2 the pressure it does at no load.So I guess I need to start with a low side test ( because it is fairly simple) and go from there.
May I ask where you sourced the table for the flex fuel sensor from?
I am thinking mine may need to be adjusted or changed, as you seem to have no issues with E30, but I do.
Ed
To Another boring Z06 intake+tune+E85 dyno thread
Old Feb 6, 2017 | 06:39 PM
  #38
Higgs Boson
its in the tune, and not the flex tables.
I also have a cai, pulley, stat, and headers and can run up to E50 or so at 6ms pulse width but typically keep it to E35-40 so I can run 4.8.
There is nothing to gain for you from E30 to E85 except run lean.
Old Feb 6, 2017 | 08:42 PM
  #39
WS6JJP's Avatar
WS6JJP
Higgs, do you have any type of aftermarket low pressure side fuel system to be able to run up to e50? I wonder how much ethanol content you could run if you were to put a low side system on?
Old Feb 6, 2017 | 09:21 PM
  #40
Higgs Boson
it doesn't really work like that. you run out of time to inject between exhaust valve close event and spark.
you need bigger injectors that can inject more fuel in that small window.
without bigger injectors they will lengthen the spray time further and further until the fuel rails lose pressure and then the low side loses pressure too.
you can install a low side and keep that pressure up. you can install a cam lobe to help keep the high side pressure up. then you still have the injector issue and end up needing meth like everyone else.
