Yeah I keep forgetting about the injector size and window of opportunity to spray (soi). I'm going to go the bolt on route (halltech, exhuast -no headers but 4 cats deleted) 160 stat, 18% lower, 103mm TB, ported blower/snout, low side fuel system but no meth) so I'm not sure what my max ethanol content will be but hopefully it makes some good power.
Haha yes, same Terry Burger. In 2008 I started a company selling BMW tuning systems I designed and I've been doing that ever since. The Z06 is just a personal toy for fun. No plans to get back in to GM tuning other than helping friends, arguing on the forums, etc. I sold my C5s in 2005 when my wife got pregnant and I've been wanting another Vette ever since. The close out deals on 2016s were just too much for me to pass up. Plus, it makes a good race comparison car for all of our BMW tuning marketing.
i LOVE it Terry! Ive been following you through all my N54 engine vehicles even my previous s55, and now into my LT4...
Look forward to the 103tb + ported snout results. Hurry up bud.....
it doesn't really work like that. you run out of time to inject between exhaust valve close event and spark.
you need bigger injectors that can inject more fuel in that small window.
without bigger injectors they will lengthen the spray time further and further until the fuel rails lose pressure and then the low side loses pressure too.
you can install a low side and keep that pressure up. you can install a cam lobe to help keep the high side pressure up. then you still have the injector issue and end up needing meth like everyone else.
Maybe I will just stay where I am at the 25% level, and think about other ways to go faster.
Are your comments pertaining to a ZO6, or a LT-1 ?
Ed
Took way longer than I wanted to get the prototypes in. It's sort of a slow process as each change needs to be 3D printed, assembled, flow tested, and then you tweak and repeat several times until you get what you want.
Anyway finally happy with the results on the flow bench. What we've come with is a dry (no-oiled) drop in filter that will not throw off the MAF readings (which result in a leaner AFR and higher timing advanced than tuned for) and significantly outflows other drops in on the market. I'm hopefully based on flow testing we'll find dyno performance similar to aftermarket intakes which have been properly tuned for to run safe AFR and timing values. Only without the need for special tuning.
The OEM intake piping actually is huge and has almost no restriction at all. The problem with the OEM intake especially at higher flow levels is with the filter itself and how it mates to the OEM piping. The rubber filter bases are molded so large they constrict airflow. To solve this we've come up with a much higher flowing base that is still a direct fit to the OEM airbox unmodified. Also reworked the filter pleating depth, material, and some other aspects to further reduce restriction.
In doing that we identified some further areas for improvement by modifying the factory airbox. So I'll be dyno testing two versions. An unmodified airbox with the new drop in, a modified airbox with the drop in+ version, stock, and of course the AFE intake.
I don't want to share too much additional information on the drop in+ until I know how each setup performs on the dyno. It's possible the drop in alone will provide adequate flow for 630whp or whatever eliminating the need for the drop in+. But on the flow bench minor (outwardly invisible) tweaks to the airbox which anyone could do at home in 15 min did provide a significant reduction in restriction.
This is great! Thank you. It was funny before I listed my Haltech CAI for sale I had the zany idea of just cutting it and the stock intake in half and then scotch taping the stock tube to the Haltech filter housing. I'm sure it would have worked!
Are your flow number through just the filter or through the complete intake system to include the Intake pipe, MAF, Screen and Filter?
We're maybe the 2nd or 3rd most well known BMW tuning company. So its probably not hard to find our website. But forum rules dictate I can't discuss business here.
Got mine turned up to 3 o'clock for 8,000 miles on 93 octane...runs great on my 650IX... slaps C7's around all day, thanks!
Terry, By the looks of your excellent photos showing from inside of the filter, you are maintaining the screen? I know it helps straighten the air flow, but I also know on a roots blower application, when used between the inlet side and the injector hat (or carbs), it adds a 30% airflow restriction. What are your thoughts on the stock screen?
Let me rephrase that. The over the counter screens available for roots style 6-71 and/or 8-71 blowers, reduce the available square inch area of the supercharger inlet opening by 30%. Not sure what it is for the C7 Z06, that's why I asked Terry the question.
I think Terry is talking about screen removal and some trimming in the area of the plastic that the screen is attached to. I have not looked at the OEM cai in a while so I may look it over again. Oh, really not sure at all, I will have to take a look but there may be something that can be done to open the space up around the outside of the air filter some too.
