Tony Mamo Ported TB installed
#221
I appreciate all the positive comments etc....thank you
Regarding the issue with MRHTRD, I think its likely the vitesse thats creating or should I say compounding things coupled with all the other mods (quite a few on this car) where the computer finally says "Uncle". Now the Vitesse controller is quickly opening a far more efficient TB that's moving alot of air and I think its just going to be an issue unless you can address this in the tune (or just address the light function in the tune).
I suspect without the Vitesse it would work OK and at the end of the day having the better flowing TB is going to make big changes in your airflow and your actual power output where the Vitesse does none of that....it just plays with the opening speed of the TB....the volumetric efficiency and the output of the engine hasn't changed a bit which is not the case with the ported TB.....that gives you the extra response and a bunch more power and torque from the real improvements in actual airflow.....your engine is moving more air with a ported TB bolted to it.
I would try deleting the Vitesse from the equation and see how that goes.....its the first thing I would try (with the exception of disconnecting the battery for 10 minutes and seeing what happens after).
I could port something less aggressive but I think the best play is to tune it out or ditch the Vitesse and get the most gains in airflow from the TB swap
Hope this helps!
Regards,
Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
MRHTRD (06-21-2017)
#222
Seems NyVetteguy007 is my unluckiest customer....LOL
The first TB I sent him was damaged in shipping....USPS dropped the package and it cracked the extended plastic housing area where the wire harness plugged into (in spite of really good packing in the box....those who have received one of my units can vouch for how well I pack them). So I sent him a replacement unit right away and for whatever reason he is dealing with this idle hunting issue which is a first with approaching a couple of hundred units out in the field.
Anyway as the saying goes, Im hoping three is the charm! Working on his 3rd unit this week. Im not sure what other mods or conditions might have created the idle hunting he is experiencing (possibly even a bad TB), but hopefully we get it right this time!
Regards,
Tony
Regards,
Tony
Third time is a charm!
Received the TB this morning and installed it...no idle issues and holy crap..what a difference in throttle response...definitely a worth while..killer mod
Loving it and can't wait to drive it more
#223
Can you describe what the "hunting" for idle feels like? I've noticed with mine that when I rev it sometimes there is a feeling like a stutter or a dead spot and I'm wondering if that's the same thing that you experienced. I put Tony's TB on the car right when I got it last month, but due to travel and bad weather I really haven't had the chance to drive it much. In my limited experience with the car, however, I've noticed that issue with the idle so I'm wondering if maybe I got a bad TB like you did.
#224
Sounds like what you have when you rev is normal, you mean just sitting there and hitting the throttle?
#225
Doesn't sound like you have an issue...when I say "hunting" it was literally going from 500-700 rpms up and down, up and down...you would notice, in my case it was probably a defective TB...
#226
In real world applications and driving around the ported TB eliminates most of the annoying stumble the OEM TB is plagued with and the tip in response and power and torque are enhanced significantly.
Mr. NyvVetteguy.....I'm very pleased the the new TB I sent you cured the idle hunting issue!!. Im actually going to try that TB on a local C7Z and see if I get the same issue. Never had one hunt for idle before....if that happens again Im going to toss it in the trash and chalk it up to a bad unit which would be the first one I have received (and I have purchased hundreds of OEM new throttle bodies). Should be an interesting test
Last thing I thought I would address is letting you guys know the GM supply is completely exhausted. They are changing vendors and changing part numbers and I don't know when there will be availability again and whether they will increase the price (due to the high demand they probably never counted on).
Not sure whats happening. I have started a back order list which will be handled on a first come first serve basis so when I finally do get inventory again I will start shipping to the guys that committed earlier (older orders) but I have no idea when the next wave of TB's will actually arrive.
This is a total disaster on this end as it creates alot of extra emails and PM's sorting all this out and I will be playing catch up for a very long time if GM takes many weeks (or months) to start shipping the new units. I really hope this gets resolved soon!
Regards,
Tony
#227
That's whats left of the OEM issues and it likely only happens when you goose the throttle harder with no load (free rev). Put your stock unit on there and see how much worse that stumble becomes!
Regards,
Tony
Regards,
Tony
I can't say enough how this is truly game changing as far as throttle response...great stuff
It will be interesting to see if the TB I sent back to you has the idle hunting problem on another car...
As for the supply issues, happy I have mine now
#228
HEY tony I'm intrested in the ported Tb but I did read u port different on the lt1 vs. LT4 supercharger I have a stingray putting the LT4 blower on it so which port will u think is better to go with
#229
I got my TB today installed on my 17' Z06. I feel like 90% of the hesitation between 1k-2.5k rpm and light throttle is gone. I did about 5 WOT runs up to 100mph and no CEL with BMS filter + TB.
#231
Worst case, in the event you have an issue I swap it for something milder like the LT1 applications get....no big deal.
Glad you were pleased with it
-Tony
#234
I specialize in airflow....been involved in the performance industry for over three decades. Im a cylinder head and intake manifold designer by trade....was head of the R&D Department and handled most of the AFR (Airflow Research) cylinder head and intake manifold development for 15 years before embarking on my own gig running Mamo Motorsports almost three years ago. I have logged thousands of hours in front of a flowbench. Google my name if your unfamiliar with my background.
Compare the quality of the execution of my units to my competitors.....that's not something easily done but would encourage you to seek out others who have. I have invested alot of time experimenting and perfecting this product....for the select few that have issues I modify if necessary to make sure its right....no one leaves unhappy.
This thread has how many positive and glowing reviews about my products and customer service??.....LOL (Honestly if your not feeling comfortable at this point Im not sure what more I could say to help).
And I offer a money back guarantee as well....if you don't feel it was/is worth every penny I will refund your money.
That's it....the rest is up to you but as I have stated previously, GM is out of new cores at the moment and the best I can do right now is put you on the pre-order list I have going already that I will be filling on a first order first served basis once supply from GM is available again. For others reading that might be interested as well, I only need your info....wont be processing credit cards till the day the the TB is in a box and ready to ship.
Hoping the General doesnt bobble the ball too long...
Will update this thread with any new developments as they pan out
Regards,
Tony
#236
Guys,
Hope this helps!
Regards,
Tony
Hope this helps!
Regards,
Tony
Sorry for taking so long to answer here. I did remove the Vitesse product and the check engine light quick went away and I have not seen anything further.
quick note......The car runs far better without the Vitesse and with the new throttle body than it has ever run !! Very smooth acceleration, no lag to speak of (at least I cannot notice it) and the throttle power is just as good without the Vitesse and fuel mileage is way better, although I did not buy this car for fuel mileage !!
Your product is second to none and so far I am very happy with the results. We may need to look at my 02 Z06 again in the future....................
Dave
#237
I thought it was interesting that someone installed a Katech TB and also is having idle surging problems.
https://www.corvetteforum.com/forums...b-install.html
#238
#240
17 Z w TM and BMS
FYI- my 17 Z A8 runs just fine w no codes thrown etc. I have the infamous Tony Mamo ported throttle body and the BMS filter. Very happy w both at this point.
