My Katech valve cover install
.........as HRT stated: $1K will net you roughly 20-40rwhp with some simple add-ons. I'll never understand the engine dress up theory much as I don't understand the carbon fiber plastering either.
I spent a fair bit on CF goodies, but I get to see it everyday and in changes the look of my DD big time.
If you are a track guy, the priorities are different.
All cool right
I got a set of red ones sitting in my garage waiting to be put on in a few weeks. I have a expansion tank in the same area, do you have to remove it to change out the valve covers????
Bad Dad (02-23-2017)
Did you have to take apart some of the PCV fittings,etc out of the stock valve cover and incorporate in the katech valve cover to make it work.
They come with one nipple per cover you will need to rework the pcv lines the factory fittings will work, then you will lose center of passenger side no big deal I will be using the MM oil catch system and I am replacing all lines with HPS black silicone hoses to reroute out of sight did one today looking better every day. You will need a dremel to cut off the tabs for the wire harness.
Are you able to reuse the valve cover gaskets when doing this????
SharkbyteLT4 (03-12-2017)
The following 2 users liked this post by AWARE02:
Bad Dad (03-13-2017),
#33
I don't get it. These painted coil covers look much better to me, and much cheaper. You guys Iike to see the coils?
#36
Bad Dad (03-18-2017)
#39
