Performance differences vs. driving modes
Old May 15, 2017 | 05:21 PM
jimman's Avatar
jimman
Default Performance differences vs. driving modes
Search wasn't productive:
Are there engine parameter differences in the various driving modes.
Old May 15, 2017 | 05:37 PM
davepl's Avatar
davepl
Nope....
1) Engine performance does not change by driving mode.
2) Engine performance does not change during the first 500 miles.
3) Engine performance does not change when placed in Valet mode.
Even though it'd be pretty trivial from a software viewpoint to do these things, GM would have to emissions-certify each of the various "tunes". And it would complicate CAFE calculations too (unless you just assumed worst case I guess).
Old May 15, 2017 | 05:40 PM
jimman's Avatar
jimman
Originally Posted by DAVE396LT1
Nope....
That makes sense
Old May 15, 2017 | 05:42 PM
jimman's Avatar
jimman
Originally Posted by jimman
That makes sense
Although what about Econ mode
Old May 15, 2017 | 05:46 PM
TXshaggy's Avatar
TXshaggy
One of the 12 variables controlled by mode select is Throttle Progression which adjusts throttle sensitivity -- how quick (or slow) the throttle responds to input.
Old May 15, 2017 | 05:50 PM
NSC5's Avatar
NSC5
The performance may "feel" different because throttle progression does vary by mode as will shift characteristics if you have an automatic transmission. Econ mode will force V4 operation as much as possible so the engine will feel more sluggish until you use sufficient throttle to go back into V8 mode.
Most of the time I stay in touring mode for the softer shock setting, steering set to sport (touring mode steering is far too light for my taste), engine sound management set to track or sport, and gauges set to sport with engine temperature displayed in the DIC area and oil pressure and temperature as the pocket gauges.
But everyone has to develop their own taste for what set of parameters feels best to them so I encourage you to spend some time playing with the different modes and also unlinking steering, exhaust (engine sound management), and display from driver mode to experience the different combinations. I drove for the first month with steering linked to driver mode and didn't realize how much better steering feel is in sport mode.
Old May 15, 2017 | 06:00 PM
Bill Dearborn's Avatar
Bill Dearborn
I don't notice any sluggishness when running in V4 mode. As soon as I touch the gas the system switches to V8. On the street you rarely get close to going WOT and any sluggishness wouldn't be noticed unless you went wide open in some gear like 3rd, 4th, 5th or 6th. I usually drive around town in 5th or 6th gear and just a nudge of the throttle brings the engine into V8 mode and I have to be careful not to run into people.
Bill
Old May 15, 2017 | 06:03 PM
jimman's Avatar
jimman
Well that also makes sense
Old May 15, 2017 | 07:55 PM
davepl's Avatar
davepl
Good point. That'd affect things like how aggressively the engine goes into V4 mode, but not the engine calibration. But the car gets mileage tested in the default (Tour) mode, so far as I know.
Changing the calibration (spark, fuel, whatever) would change emissions but throttle response rate, gear selection, shouldn't affect the engine calibration at all.
To be clear, I'm just deducing this from the practicalities of certifying an engine and assuming that they don't do this. There's nothing I know of to prevent them if they wanted to go to the extra work.
Old May 15, 2017 | 09:33 PM
Z06NJ's Avatar
Z06NJ
Speaking of performance, why does the car feel like a beast whenever I get a full tank of gas? It feels like something activates, in any mode...Tour, Sport, which makes it appear to have more power. Is it just me or others have experienced this??!
Old May 15, 2017 | 09:45 PM
tzoid9's Avatar
tzoid9
Bill
Bill you make a great point with your response, but it sets up a second question, from what you mentioned regarding the ECO mode. There were a number of reports a while back about engine failures (I think it was dropped valves, but not sure) on M7 Z06's when they were run in ECO mode. I've never put my car (2016 Z06, M7) in that mode ever, since reading about that failure. Have you or anyone else heard anything about that problem being cured, or was it isolated to a certain S/N range, still exists, or anything one way or another? Thanks.....
Old May 15, 2017 | 09:52 PM
why1504's Avatar
why1504
St. Jude Donor '17
I also would like to hear Bills opinion here.
Old May 15, 2017 | 10:00 PM
HighBeta's Avatar
HighBeta
Amat Victoria Curam
Hmmm. Can't say that I've noticed that.
Old May 15, 2017 | 10:14 PM
davepl's Avatar
davepl
I've not noticed that myself, though maybe it just hooks up better because of the weight over the rear tires, and hence -feels- faster?
One could imagine that when the car sees a large amount of fuel added, they could wipe the knock counts and start from the "high octane" starting point again, but I have not seen anything to indicate that's the case.
Old May 16, 2017 | 09:44 AM
Z06NJ's Avatar
Z06NJ
Very good point actually. It could be a placebo effect of the additional weight in the back!!
Old May 16, 2017 | 11:44 AM
Dabigsnake's Avatar
Dabigsnake
OK, don't have the facts in front of me, but I remember reading and seeing a chart that explained that if your tires were cold there was not full power available, and that differing modes did not allow full power?? I once mistakenly got into sport mode on the track and I did not have full power down the straight, but only a few MPH off.
here we go:
https://www.corvetteforum.com/forums...rack-mode.html
Old May 16, 2017 | 11:56 AM
jvp's Avatar
jvp
"Ask Tadge" Producer
You're mistakenly crossing the streams a bit here. Think of the traction control system in its totality as a hammer. What the system is doing with the tire temperature monitoring is telling that hammer how hard it can hit the car to 'straighten' it out. Or how far towards the adhesion limits of the tire the hammer can let the car go before it stops the "fun" (PTM). But it doesn't come into play for normal power delivery.
Basically, if you don't hear the BRRRRRRRRT of the PTM, it's not doing anything. Nothing else will limit the car's torque delivery based on tire temps.
To Performance differences vs. driving modes
