Just curious what rim + Drag Radial combo would you guys recommend?
Just curious what rim and tire combo would you recommend? Preferably to match my black wheels in the front? Thanks!
NorCal can fix you up I got my 19" replicas thru him and put Nitto NT05R's in 345-30-19 they hook pretty good and are very stable at high speeds BUT you need to have non runflats up front. I bit the bullet and bought another set of OEM front wheels from the outfit in Florida (you can find them on EBay) then mounted the new Continetal 2's in the front. They are non runflats. So now I have a set of wheels with runflats for road trips and a set for cruising locally.
the fronts I bought from an eBay vendor from Florida.
thats great to hear I was thinking about the replicas on eBay I was a little skeptical on durability on hard launches I've rims snap before 🙈 Where did you get yours from? Thanks
We purchased ours from Bob @ OE Wheels (561) 445-7606. Bob's out of Florida, I think around Ft Lauderdale. Straight up guy and easy to work with. As for durability . . . that's a crap shoot. Bob said he's never heard of a wheel failure, but that doesn't mean it couldn't happen. If your C7Z is an A/T car, I wouldn't worry to much about it. Just be smart and check the wheels after every pass.
If you call him, tell him Jack/Illinois - Shafer Wines referred you, he'll get it.
Good luck!
Good luck!
Good luck!
Good luck!
Actually phew.. canceled just realized that these wouldn't clear the carbon brakes.. I'll call him in the morning for the 19's lol
I do think it could be more stable (the MPSS felt more stable, and the C6Z with Nittos did as well for some reason), but it's way better than the MT ET SS I had before that!
I run Nittos NTO5R 345/30/19. I was a BFG DR guy for a long time, but Nittos have improved tremendously over the past few years.
I'll eventually spring for skinnies up front or do the mods to have a complete drag pack as the RWHP/RWTQ increase.
I ordered my replicas with the TPMS and the stock center caps (no emblem) and just popped out my OE caps.
I purchased my Nittos from Discount Tire. Reason being, they will match or beat other prices, at least my Discount Tire does. Bring a print out of the best deal you can find.
Good Luck!
Good Luck!
I went with the 18s with MT mounted up. The Hoosier also does very well. For an optimal 19" i think the only show in town is the Nitto, in terms of DRs...
thanks for chiming in! Do you think the 18's would clear carbon ceramic brakes? In the rear?
Don't fit.
I have the 18X12 chrome replicas. Tried them on a buddies C7R with the carbon ceramic brakes and they don't quite clear the rear calibers.
ICE enthusiast
