Had some bird shit stain my paint
thanks
Amat Victoria Curam
In my experience, admittedly with a black Infiniti, ceramic coating was the only way to keep my son's car from getting destroyed. His assigned parking spot at school was right under a "well populated" tree for years.
Moderator
Received 3,622 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
Ceramic Pro !!!!! Have had it on my car for a year. No wax needed , brilliant shine and most importantly has protected the car from birds, sap and road paint encounters
To the op, buffing or a very fine wet sand then polish
= as good as new. Your ok bud, wasn't on that long.
Received 3,117 Likes
Finalist 2020 C7 of the Year -- Unmodified
Xpel ultimate is your friend and good luck getting the bird poop stain off the paint.
Moderator
Events Coordinator
It varies on the package and your location. With paint correction---$500-1500. I have Expel on front and select other places. Ceramic Pro over.
Had my shark grey Z in my driveway for a few hours yesterday,otherwise it is garaged.Had some bird **** on it,cleaned it off.It left a mark in the paint that I cant get out.Car has at leat 4 coats of Z2 and a couple coats of Zaino clear seal.Hard to believe it left a stain.I clayed it,waxed it,still there.Never had this issue with any car that ive owned
Clif
Forget the polishing and compound. If it is acidic to the paint it will take sanding 90 percent of the time. Trust me when I say this, use 3M Trizact sand paper. You can buy it for a sanding block. (I used 3000 to 2000 levels) This will allow you to cure any minor scratches in the future, also. This type of paper is actually padded where you dont have un-level sanding contact. You can buff out the marks with 3M compound or even Meguiars Ultimate compound with a microfiber pad.
