Winter Storage (6 months in WI)
2015 Z06 - Three questions for storing my Z06 in garage.
1. Should I store with full tank of fuel or 1/4 tank of fuel?
2.Should I remove tires and store on blocks (any suspension issues)?
3. Start engine monthly or not until ready to drive?
650hpvette (10-15-2017)
2023 C2 of the Year Winner - Unmodified
2020 C8 of the Year Winner - Unmodified
2020 C6 of the Year Winner - Unmodified
2020 C2 of the Year Finalist - Unmodified
2017 C2 of the Year Finalist
2016 C2 of the Year Finalist
2. Leave the tires on , but inflate to 37psi
3.dont start the engine unless you can drive it 10 plus miles!
4. Hook up a trickle charger to the battery
the first thing you need to do is change the oil and filter.
then 1/4 tank of gas, fuel stabilizer and Marvel Mystery Oil in the gas (coats the injectors) then drive the car for 10 miles.
Jack the car up and put jack stands to load the suspension. then you can let all the air out of the tires.
genuine gm accessories 22969090 battery charger.
cover and leave it alone until spring time.
Either of the first 2. No need to remove tires/wheels or raise. The best is don't drive unless you can get 10 miles or more to fully warm up oil & burn off any moisture. Remember, what you see about storage is "ONLY OPINIONS".
Oldtimer
The only thing I do differently is put about 45-50 psi in the tires. (Just remember to let the air out in the spring.) I've stored cars for years and never had a problem. I live in Northern Illinois and will putting mine away in about 3 weeks.
1. Change oil and filter
2. Fill up w/gas to avoid condensation
3. Add 3-4# to tire pressure
4. Wash the car
5. Hook up battery minder
6. Cover the car
7. Call my insurance company and cancel all but "comp" on the car for six months.
Pray for a warm pleasant day in late March!!!
Living in Salt Lake for over 20 years, my October routine for my Vette and other toys was:
4. Wash the car
6. Cover the car
4. Wash the car
6. Cover the car
I didn't drive the vette for 2 months and half, I am wondering about the gas in the tank, should be ok to drive? gas go bad after 3 to 5 months right? and tire spot occurs after many months maybe 4 to 6 or so?
I have been storing my car for 5 to 6 months every Wi. winter, stabil in the full gas tank, pump the tires up, ctek battery maintainer, oil change, cover it up. No issues after bringing it back to life. Every year for 12 years
