GM cold air intake for ZO6
#181
Being at the best prepped track in cold weather with mine shaft air and having time to sit out there helps too. But all have no bearing what so ever on the new C7Z06!
#182
Received 1,817 Likes
Yes, the A8 has a lower first gear, but that also results in it needing to shift out of first gear sooner, with the resulting rear-wheel-torque drop from the earlier shift.
Perf n Restore (03-21-2018)
#183
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
I believe the Halltech and others cost more than the GM system. Also no cutting anything to install.
#184
Are you still harping like a way-past-menopausal and Alzheimer's-afflicted old lady on that old chit, despite it having been invalidated time and time again in numerous threads?
Just refer to the GM 0-60 times showing the A8 faster. I could show you a couple of you guys black but I would be some how wrong and white would be claimed and argued till the cows come home so I'll just go with.
Whatever dude.
#185
From head of GM aftermarket parts (at Sebring Corvette Corral):
On LT4 - +8 hp / other engines +14 hp. Available mid-April
A little disappointing. Wonder if a BMS filter will fit the housing?
The following 2 users liked this post by reasonable suspicion:
rikhek (03-19-2018),
speedsquad (03-19-2018)
#188
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
I want one too.
#190
Sad...
foreverfuelie (03-20-2018)
#194
Keep in mind BMS or any other aftermarket filter don't have to adhere to the filtering performance numbers GM has set. If GM releases a filter that filters less and translate to more power, but ends up with higher warranty claims thats a loosing proposition for them. Hence GM performance parts are handicapped from conception vs. pure aftermarket.
#197
Gotta love the one-off glory runs always used for power gain claims
#198
#200
