The case for A8 @ Track (Road Course)?
This is more of a plea to folks that are experienced with the C7Z A8 ownership and consistently track it.
I can respect GM for providing both the MT & A8 options to the masses as their sales records reflect the success and ensures the Z06 marque continues.
That being said, for those of us A8 owners that intend to track these cars. Are we out of luck (unless we choose the $8k LG cooling solution)?
What I am hearing from successive reports is that short shifting manually as opposed to full auto on track lends to just a few more minutes of track time before limp mode.
Granted, there are a number of variables at hand (Ambient Temps/Driver skill etc)
Is there a point to have an A8 for HPDE sessions? Looking for a solid case.
The guys I've instructed were inexperienced track drivers. At the beginning of an event I've tried to get them to go into manual mode and use the paddles to short shift, but each of them has been reluctant to initially do that - they have wanted to run in auto with car shifting at redline. However, after a few laps when we get the limp mode and limp into pit row to cool down for a few minutes I'm usuall able to talk them into trying manual and paddle shifting at lower RPM. The 3 or 4 students I've had that experience with have all never used the paddles much, and they've been very poor at paddle-shifting the A8. I've had better luck just leaving it in 4th or 5th, but it still only adds a couple laps before the limp mode pops up again.
Bottom line - unfortunately I just don't see any case at all for getting an A8 for the track.
Just MHO,YMMV!!
That being said I have never placed the car into limp mode even when it’s been 96dF when I’ve been tracking the car, and I obviously run in the Advanced run groups. You have to drive it in ‘M’ mode only, and you have to short shift, preferably before 5500 rpm. Further you need to understand that even at 2500 rpm the car has tremendous torque, and in many (most?) corners you’ll be just as fast in the next higher gear versus allowing the car to rev up close to redline in a lower one.
Am I frustrated having to drive it this way; (meaning having to short shift)?, yes I am, and I definitely feel that I was lied to by GM. Further, the fact that after 2 1/2 years after I bought the car GM has done nothing for A8 owners to mitigate this overheating issue, even though the chief engineer said that it would, is disgusting.
Regardless I am generally the fastest in my run group and the car is a joy to drive as the handling is sublime, and my car has essentially been bulletproof apart from leaking brake bleeders on track which again, GM dismisses. If I was going to keep it, or if I was buying a new A8 version, I would invest in the LG kit immediately. I sincerely doubt that a decent driver who doesn’t simply run the car on a road course at 6500 rpm all the time can overheat the newer M7 models.
I have however had the PS electric motor overheat a few times in really hot weather, so now I have the GM ‘cooling kit’ installed.
Bish
https://www.corvetteforum.com/forums...-0-tested.html
https://www.corvetteforum.com/forums...-solution.html
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
Randy
Just MHO,YMMV!!
If you're a drag racer, the A8 is the hot setup, but for road course use, I haven't talked to even 1 A8 owner that hasn't experienced limp mode after a few laps, but only a couple M7 owners that have, and both were '15 or '16 models that haven't had the '17-'18 blower upgrade. That's why my '18 is an M7. Not to say the A8 is bad, I know the majority of buyers opt for the A8, but for road course use, the M7 has proven to be the better choice.
Depending on conditions I can run to redline at certain times, but mostly shift at 5500. According to GM's dyno chart, you are still getting all the torque and about 550 HP. I am going to do a post on my mods soon. I love the car on the track. I have driven m7 and A8 and I prefer the A8 for road course. If GM would have done this to begin with, I think people would have been happy. Looking at economics, the hit on my 2015 to go to a new or low mileage M7 that way I wanted it was about 20-30K. I figured it was worth taking a risk to see if the LG set up worked in its simplest form because it made so much sense and they tested it. Now that I know it does work, its a good investment to add the kit and enjoy the car. I am like you, the info from Gm said the A8 was the track car, so even though I have never owned an auto on a performance car, I thought, it was time to try an auto.
If I need more cooling, then I can add the LG or De witts radiator. If I need more, they have a package. No trans temp warnings yet.
I also added Mad Dog 24's oil cooler fins with the duct work. My oil temp have been around 265 on long sessions. I think its a good combination, no warrantee issues and simple. As for temps over 92, I have not had the opportunity to test but I think I have a little room to run in hotter temps. I will post more about what I did and the results.
For the money, the upgrade is definitley worth it unless you can swap for a m7 you like for a small amount ie less than $5000 .
I wonder what issues the zr1 will have?
If something happens and I am I'll deal with it then. My last track day I had oil and water temps higher than I liked them and thought this would be good insurance.
Just hoping for a fix that would not cost so much money out of pocket. Needless to say, GM royally screwed us A8 owners who had to cough up close to $2,000 for this 'fast shifting automatic'.
I just don't get how a company like GM can get away (in this day and age) without providing a solution. You just don't win new customers by just sweeping things under the rug.
