Xpel installer cut my paint...
#61
I got a partial refund of $3k but that's what it's going to cost me to fix the paint and get the film done elsewhere. In the end, it's just a bunch of wasted time, gas, mileage, and stress to get what I initially paid for. It's whatever though.... I'm going to enjoy the car and get it all fixed after the holidays.
#62
Working thru Xpel headquarters in Texas I was able to get new Xpel ready to apply thru them and a partial refund from " installer" (Ryan Kates, NJ) of $1500.
Check came last week. Sad situation for my 2018 GS with less than a 100 miles on it at the time and over 3000 mile drive home in front of me.
#63
#64
Not completely sure. I'll take a look at the estimate later. I went to 2 Chevy dealer body shops and got quoted $1490/1500. I believe it was remove film + paint/blend/clear? They're also pretty sure that once they remove this film on there now that there will be more cuts since the bottom parts of the panels appear to all be trimmed.
#65
#66
If they just removed the current film and installed new film correctly, you'd see the cuts under the film.
I won't know if the film can be installed to mask the cuts until this current film is removed to see if there are more cuts. Even so, the bumper cut is pretty far from the edge so a proper install wouldn't go along the edge of it.
#67
I am sorry to hear about your install. Mine was a fantastic job here in Indy. I hope you get everything corrected and fully reimbursed. Keep us informed.
#68
Location: Chartres, with a cathedral of XII Century in the middle of the wheat fields FRANCE, la Belle et ses Iles
Received 1,277 Likes
Waow, amazing. How is that possible? I have seen that in the USA, xpel is very expensive, more expensive than in France. I thought it was impeccable work, considering the very high price. Here, the film is cut beforehand by computer following the car but never cut on the car, never. Look for such an installer, even if it's more expensive.
#69
So maybe a silly question why not remove the xpel yourself, I did it on my front bumper when I had to get it replaced and although it takes some effort it can be done. This way you save on the cost of someone else doing it and you can check out the whole car easier to see just how many cuts there are. Just a thought.
#70
Some use precut panels, some use on the job precut panels that allow a bit of overage to be cut and some use actual rolls of wrap and cut on the car. My neighbor has a wrap company and he says the guy that taught him how to cut the wrap taught them how to do it, then demonstrated by laying wrap on his arm and starting at the crook of his elbow cut the sheet in half down to his wrist. No blood. He was pretty impressed. Some of these guys have not taken that class. Also an exacto cut can be repaired on the car. But again it takes a professional. Spend some time on Youtube watching AmmoNYC's videos. His work is totally amazing. The things he can repair on exotics without a panel repaint can't be imagined.
#71
XPEL factory trains each installer and certifies they know how to do the job right.
Sad when installer ruins install and does not have to answer for it thru company that has you use their trained installers.
#72
I'm not sure what this company uses. It looks pre-cut because some corners flow perfectly with the body lines but the same panel will have a corner that looks butchered to hell. I always thought xpel was pre-cut and installed on each panel but every install from this car has had different results on every panel.
I supposed at this point I can remove the film myself, but I told myself to forget about it until after the holidays. I've been stressing over it for the last 2 months and it's been a pain in the *** having 1 day off a week and dedicating it every week to dropping off or picking up my car from this shop.
Once I remove the film, assess the damage, get it in the shop or try to fix it at a detail shop without painting like the above user posted (videos by AMMO), and get it taken to derek at Atlanta protective films. It gives me anxiety even thinking about having to take care of all this every Monday(my only day off) for a month or two.
#73
I think that before entrusting a car of this price, rather than a telephone interview, it is better to take and be wasting time traveling by surprise visit and realizing on the spot. consult with people who have already done this work in the store you want to choose. That's what I would do.
#74
I would avoid respraying the panels and just have a detailer try to minimize the damage. i've had my car dinged and respraying has it's own headaches too even when done by the so called pros.
#76
I had the entire front of the corvette covered, including the fenders,and all the aero parts around. The guy used an Xpel equivalent, much cheaper, US made. Everything was cut by digital machine as in a textile factory. the most impressive is the film around the Corvette logo, stealth !
#77
Such BS! I took mine to the dealer and my installer came to the dealership and did the whole deal in one afternoon. Perfect no issues. This guy owes you a lot and next time just know no more than 1-2 days to install or sometime is a miss hope you get your money back!
#78
I couldn’t live with that...I learned the hard way(like you), just paint as needed and save your money. I’ve had two rock chips in the last 7 years driving at least 35k miles a year. Sorry for that bs work you had done.
#79
Just one more reason why I used Expel once but will never use it again.
#80
Account disabled by request 1 Mar 2018
Wow! What a sad story this is. Feel bad for the OP. After reading this thread I will never get a wrap or Expel install. It’s just not worth the risk and aggravation. Thanks for the education OP.
