Anyone using neck restraints?
I would also comment that folks using a race harness and HANS in conjunction with a typical harness bar for track activities in their Corvette are fooling themselves if they think this provides the margin of safety associated with the HANS. In an incident involving a significant frontal impact, which the HANS is indeed designed to mitigate, there is a very significant probability that the single mounting point of the typical harness bar will shear, allowing the driver to move forward into the steering wheel or worse. I've personally seen this happen and the results weren't pretty. The HANS device is designed to be effective when used with a full roll cage and only provides a placebo when used with the typical harness bar for Corvettes, especially since in most cases the airbag is still in place and active.
Bob Neff, Regional Executive
Texas Region SCCA
I was wondering if you have any documentation of actual incidents that shows the danger. Most of us don't get to see what happens to the safety equipment in track accidents and I have never seen a harness bar that failed when looking at a few crashed cars after incidents.
However, I know that doesn't mean under certain circumstances and force levels the point may be reached where the mount may not hold up as well with a bar fastened to it as it would with just the stock seat belt end.
I have consulted with Joe Marko from HMS Motorsports who is a recognized restraint expert and chose my belts based on his advice but he flat out told me he has no way of knowing if my harness bar or the harness bar mounts would hold up in an incident of sufficient force. The manufacturers of the various C7 Harness bars have all said they hire somebody to do a force analysis of their bars but I have no idea whether that analysis includes the stock mounts that are in the B pillar. I don't even know if the strength of those mounts is a matter of public record so somebody could use the data in an analysis.
Bill
I've installed a few belt bars in my day. Like Bill asked does anyone have any destruction info on these? I'm with all of you I always question the simple mounting and the bars strength. Especially with 2 bodies moving forward during a high speed frontal impact. We were pleasantly surprised of the strength and thickness of the aluminum bulk head GM choose to support the car once we choose to Tig the brackets too it.
Funny just before i read this post i got an email about an upcoming dinner with our local SCCA! Wish i had more time to spend with the group.... some day.
The GT seat pass throughs are A.) to close together & B.) to low
Unless you're very short the pass harness will be making contact with the passthrough and using that part of the seat as a deflection point for the harness.
Keeping in mind I am short and the GT seat passthroughs were still too low.
You should change seats, install at a minimum a harness bar to correct the angle.
Safety is a system that requires every component operating in unison. One of those things not setup correctly or even used at all jeopardizes the safety of the entire system.
That's how I configured my car, that's a completely custom fabricated rollbar. but it's also a dedicated time trial car.
Kyle
No compromise there! I remember seeing your set up a few years ago here. Someone should mass produce a 4\5 point bolt in rear cage and harness support for the C7's. With the versatility to still be able to use the rear storage area.
Bill
Harness bars are designed for the simple purpose of stabilizing the driver in the seat so that he/she can use their arms/hands/legs for actually driving the car rather than holding themselves in position. While they're quite suitable for autocross type events they are not designed as a safety device, as many folks unfortunately and incorrectly assume.
While there is absolutely no way to be "safe" in a track environment there are ways to mitigate the risks involved and the HANS device is one of the best, but only when used in conjunction with a properly designed and installed roll bar or roll cage that will allow it to perform its designed function. A harness bar that attaches to the B-pillar simply cannot do that.
Here are some pics of the most recent incident I've personally witnessed. Brakes failed going into a corner at 90+, car left the track and impacted a tire wall pretty much head-on, harness bar sheared on the driver's side upon impact. In this case the driver may have actually been fortunate because he was not wearing a HANS and the impact was so severe if the bar hadn't failed he could well have experienced the type of skull fracture the HANS is designed to prevent. Regardless, my comments are provided only to hopefully make folks aware of the limitations of a harness bar and the risks associated with using one in lieu of a true safety device when tracking their car.
https://www.corvetteforum.com/forums...ness-bars.html
In there forum member Dan H. posts up info from the PCA Potomac Region about their requirements to meet the PCA National requirements that are coming up for their DE (Driver Education) program:
Thanks for coming out to play with PCA Potomac in 2017! We hope to see you again this upcoming season and thought you might be interested in a couple important rule changes for our DE program:
EFFECTIVE IMMEDIATELY: a HANS (or comparable) device is required when using a harness.
EFFECTIVE JULY 1, 2018 (in anticipation of the forthcoming mandate from PCA National): occupants in vehicles equipped with only a "harness bar" will no longer be allowed to use harnesses; a roll bar must be added.
So...whether this will be adopted by other track day organizations or not remains to be seen, but I know a lot of Vette owners run PCA events, and it sounds like all the regions will need to meet the upcoming PCA National requirements sometime later this year.
Just an FYI so hopefully you aren't surprised when you show up for a PCA event later this year!!
rhneff, can you comment on whether SCCA may be going in this direction???
If you're going to "do safety" you need to do all or nothing. 5 point harness, cage, hans, and rigid seat.
3 and 4 points will let you slide out from under them without an anti submarine belt.
With a suspension seat and harness you're at risk of breaking your back because you can sink into the seat and then slam back up into the harness. This isn't as big of an issue in a C7 as the seats don't have a lot of movement but fiberglass or carbon fiber race seats do a much better job at containment. Just adding this into the discussion for completeness.
With a harness and no hans you're at risk of breaking your neck since your body is immobilized but your head/helmet isn't.
With a harness/hans and no cage if the roof collapses at all it comes down on to your head and pushes your head down onto your spine.
With a cage and no helmet or no harness you're at risk of hitting your head on a tube.
