Tiny bit hooked, newb track questions
. Please be kind.So I’m not willing to admit it, completed my first track day at COTA in my own Z, but I might be a tiny bit hooked. Spring Mountain started it, I blame them lol.. I’m more glad that I made it home unscathed than my less than expected personal performance haha.
Unfortunately the Z is my only car and my daily driver, so I can’t get too crazy and do this very often (hoping maybe 2-3x a year) but after a full day my tires are pretty ratty. Ratty enough that the ride now feels rough.. I’m guessing they need balancing due to all the rubber pickup/loss? What’s the situation there? Is that normal, not normal? I’m hoping it’s the tires and not something else..
Thanks!
I heard there was a 2017 Z that also experienced overheating.How did you do?
Thanks!
Interested to hear what folks say. Unless you locked it up or spun and flat spotted the tires not sure what it would be- maybe bearings ?
On the bright side, I improved a bit more each session so I'd call that a win. I didn't get an overheat probably because I didn't push very hard. Dash engine temp gauge got up to 265 IIRC but I wish I had better data, was too pumped and messed up on my PDR
I swear I set the start/finish but it didn't capture laps. Next time I'll remember to check after each run.. lesson learned.
No didn't spin (thank god) but one dude did right in front me, hit the wall
.. but most of if not all of my tires have lumps here and there on them.. seems to be less now but that could be my conscious hoping nothing's wrong
best case I'll take em off to check em when I get a chance..
I suppose a not impossible third possibility is you bent a wheel on curbing or an off track excursion since these OEM wheels are practically paper-mache.
If it is that.. what’s some decent track wheels that won’t break the bank but yet aren’t paper mache.. ideally some that could fit the stock tire so I can at least keep it close to stock and flip flop the use being that it’s my daily..
Bill
Any advice on a set of decent not too $$ track wheels? I'm probably asking for the impossible here though
Preferably a set that can still fit the stock MPSS tires.. I was considering buying used GM Z06 stock wheels (some decent ones for sale in the forum, but if they're truly that fragile, maybe not?) As for still fitting the stock size tires, I'm not good enough to say the MPSSs are bad.. seems fine for me.. or MPSCs are about the same price so they're also an option.. don't see a future with me on slicks, maybe.
Again, not looking to break the bank.. just a 2-3x a year thing so something I can switch out for the track and switch back for daily wheels/tire after..
As an aside, I see many folks go with 18s for track, I'm guessing for the better selection of tires? A performance thing? Lighter wheel? I'm not looking to beat anyone, just making sure I can keep driving this beast til the next one.
As for the tires feeling "unbalanced" after the track, I suggest that you drive on them for a while. The other rubber and the uneven track wear should even out in a bit of street driving. Also feel around inside the wheel to see if any pieces of rubber are stuck inside the wheel (I usually find some there, which can throw off the balance).
In terms of things to improve your track performance I'd recommend you look at (in this order): DSC controller (and alignment), higher friction brake pads (like ferodo), then putting cup 2s on the stock rims. Obviously the more you drive on track and improve your skill the better. These cars are generally capable of more than we are as "novice" drivers.
I haven't pulled the trigger on standalone track wheels because they are expensive for good quality ones. That said, I think dedicated track wheels with Cup 2s and keeping MPSS on the stock wheels for daily driving would be a good set up.
Soul Speed is a great local shop that can do a good job track prepping the Z06, including the alignment. http://www.soulspeed.com/home.php
I will say this, tracking a car is rough on it. The paint takes a beating and parts get abused much faster (brakes, bushings, ball joints, etc.) There are a number of people who drive to the track, go all day, and then drive home but it is a gamble for sure.
Some folks are telling me I'm crazy to be tracking my daily.. I agree to some degree, always in the back of my head..
If you want to purchase a stock size wheel that is reasonably priced and will hold up to track duty these should be the high on the list of ones to consider.
As for 18s the reason for that is a better selection of tires, wider tires and the chance to lower tire costs. I just purchased a set of Pirelli P Zeros for ~$750 shipped that fit on my set of 18x11 front and 18x12 rear wheels. They stick as well or better than the Cup2 tires and last as long for about half the price. You also get the chance to go with new or take off Hoosiers and Toyos. Just a much wider range of choices to keep tire costs down.
Bill
Call or text 440-915-6166
Call/Text 440-915-6166
Forgeline*Anrky*HRE*AL13*Brixton*MV Forged* and Many More....
REVIEWS: http://forums.corvetteforum.com/whee...r-reviews.html
WEBSITE: www.cw4L.com
EMAIL: sales@cw4L.com
PHONE 440-915-6166 CALL OR TEXT ANYTIME!!!
Follow us on Instagram @custom_wheels_for_less
When compared to the better known brands they are almost half price for what is a very high quality forged wheel.
