They're cool as signals, but the way this is implemented, they're sequential brake lights too. That means a couple of things - one, they're slower to be seen, but more important, when you can only see one side of the car, a brake looks like signal.
If you watch new cars that do it properly, when the brake is applied, all lights come on immediately. That's what should happen, I argue.
Whatever man. I'd say different motions capture your attention faster.
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
What would you sequence them with on a Z06? There is only one section on the turn signal (amber). The other side is a back up light (white). The red sections are tail/brake and don't really lend themselves to be sequenced.
You could use both light housings on each side, with different color LED's
The video I posted of my 73 Camaro sequences through both housings with dual color LED's, including the where the back up lights were.
So do a clear housing, with yellow in both housings for turn signals and red for brake, with white for back up.
