Z06 A8 Normal Function ?
Old May 5, 2018 | 10:31 AM
tobaccokid's Avatar
tobaccokid
Default Z06 A8 Normal Function ?
I have a 2016 Z06 A8. Seems to operate fine in normal driving, however:
When driving,say at 60mph, I’d I accelerate reasoanble hard it downshifts to 3rd or 4th, but when I then let off and resume a steady cruise speed of say, 40 or 50, it does not upshift to say 5th or 6th. It stays locked in 3rd or 4th umrilmI almost come to a stop or very slow speed.
Is this normal ?
Old May 5, 2018 | 11:06 AM
JCSIII's Avatar
JCSIII
It's probably going in performance mode. When I punch mine it goes into performance mode and if I let out and cruze after a minute or 2 it goes back to normal. Seems like i get an on screen message that says "performance mode" but I'd have to confirm that. I'd say what your experiencing is normal.
Old May 5, 2018 | 11:20 AM
davepl's Avatar
davepl
Is this normal ?
Yes. You've invoked "Performance Shift Mode" and that's normal. It'll stay in that mode a few moments to see if you're really done driving aggressively or not.
Old May 6, 2018 | 10:57 AM
tobaccokid's Avatar
tobaccokid
Thanks for the explanations. Next time I will continue after it enters the "Performance Shift Mode" to see how long it takes to revert to the "normal" trans operation.
Old May 6, 2018 | 03:02 PM
DavidC83's Avatar
DavidC83
It will revert back pretty quick. 5-10 seconds is what I usually see. Quicker if I’m coasting or slowing to a stop.
Old May 6, 2018 | 04:14 PM
RedLS6's Avatar
RedLS6
Also - Performance Shift is only active when you have the car in Sport or Track mode. It's inactive when you're in Tour, Weather, and Eco.
Old May 6, 2018 | 04:33 PM
jaden61's Avatar
jaden61
2017 C7 of the Year Finalist
you can learn a lot by playing with the throttle. Try going 60 mph, give quick stab/let off to the throttle. It will downshift to the lowest gear without redline and hold for about 4 seconds before it upshifts. Good for roll racing!.
jaden61's Avatar
jaden61
Sport or track mode
Old May 7, 2018 | 11:59 AM
BladeZ06's Avatar
BladeZ06
Quick tip.
If you hold the upshift paddle when it is holding the lower gear it will bump up to the appropriate cruising gear. Great trick if you don't want to wait for the computer to understand you are done playing.
Also if you want to drop to the lowest gear available at a certain speed you hold the left paddle; it will drop straight to that gear. Note the trans will also go into manual mode so you will have to upshift.
Old May 7, 2018 | 12:49 PM
Tort's Avatar
Tort
On a side note, they need to give PSM a button that can be activated. If not a button, make it a standalone option in the settings to go along with steering weight and exhaust valve adjustment. I am not a fan at all of the way it is currently.
Old May 7, 2018 | 07:56 PM
davepl's Avatar
davepl
They allow you to save tone settings to favorites, but not vehicle settings. It's a bug (limitation) of the software. They could "fix" it by being orthogonal and allowing you to save vehicle settings just like audio and nav stuff.
To Z06 A8 Normal Function ?
