BMS Filter, Mamo Ported TB, Borla X-Pipe - NO GAIN?!
Exhaust affects air flow too. Those 3 mods is too much for the stock tune that is why your losing power look at your AFR in GREEN terrible rich! Much like I said go back to the stock exhaust. Do just the BMS and the PTB and you will gain power like you should have made to start with!
That's what i read too.
I mean right now no CEL from the filter install but the moment it does and the code is related to the filter, then you'll see this filter for sale on this forum and i'm going back to stock.
But the PTB and xpipe were well worth the money. Definitely not changing those out,
I removed the BMS filter and went back to the stock air filter. I received the P2227 and P2228 codes like when I first installed the BMS. After clearing the codes and going for a spirited drive the car ran fine. I'm probably going to dyno the car tomorrow with just the x-pipe and PTB.
If I completely deleted the CATS I'd be with you on the exhaust having an impact but the Borla x-pipe isn't a factor here. We have effectively the same mods minus the X-Pipe yet you've never dyno'd your car so you don't really know if it's making extra power or not just a feeling. You could very well be in the same boat and not really know it as my car runs with the mods just running very rich.
for the stock tune with the other two mods but go ahead and not listen.
My stock A8 dyno with just a Halltech
[QUOTE=likeaboss;1597624313]I removed the BMS filter and went back to the stock air filter. I received the P2227 and P2228 codes like when I first installed the BMS. After clearing the codes and going for a spirited drive the car ran fine. I'm probably going to dyno the car tomorrow with just the x-pipe and PTB.
ever get the car dynoed with just x pipe and tb?
I just made the change tonight. I plan to get a dyno done tomorrow if I get time.
Did you take that dyno graph pic with a burner phone camera? Talk about an eye chart. Again I'm not saying definitively these mods don't lean out the stock tune and provide extra power by themselves. It's just in combination these three popular mods did not provide a power gain and cause at least my car to run rich. I'm not knocking any of the respective vendors yet you seem to be taking things a little personal...
you will be surprised. The dyno was just the Halltech and them I added the MAMO later and it feels really good but I'm done till my headers and new blower and 5 percent pully/balancer arrive them I'll get the tune!
[QUOTE=KillerC7zo6;1597624431]
Where have you seen an x-pipe alone or with any of these other mods cause the car to run super rich outside of my setup? The x-pipe is staying as I no longer have the stock one.
Despite the car running rich the Mamo PTB does provide a slightly more linear throttle response.
I see I didn't miss much. Lots of speculation and WAGing spoken as though it's fact. Dynos without a before and after on the same dyno and knowing exactly what the mod(s) were are worthless. I can post any random dyno and make a claim... means nothing.
The following 3 users liked this post by Tort:
That's good to hear and had I not done the before and after dyno I'd be in the same boat as my car ran fine with the mods. Doing the before and after dyno confirmed my feeling that the car was faster is just a placebo effect and the car was really running rich and putting down the same power. The only thing that truly is noticeable is the better throttle response.
i can explain what is going on here, ive been through the same situation, the car is "SMART" and gm programmed it to only make X amount of power at certain rpm points.
Your car "learned" that it was seeing extra air. Your car is running rich on purpose at this moment in time, and your car is also adjusting the throttle body blade itself, and it is not opening it 100%, and instead, only 93% for instance.
There is a high likelyhood that if you take your car to a location that is at sea level, and you drive your car to 155mph at WOT, it will go into limp mode.
It is chevy's way of preventing people from making more power. People on this forum read this over and over, but then they HOPE they can win the battle. You cant. At sea level, a stock configured z06 is already at its max power the tune will allow it to make. The only people who should expect gains in power from add ons are people 1000 ft and above sea level.
The car only shows gains the first couple days an item is added (if even that long), when you are at sea level, and after that, it re-adjusts.
IF you eventually get your car tuned... then all of these items you have bought will be beneficial.
There is a reason fasterproms was the first vette into the 9's... with the mods he did... and a tune... he is at sea level
likeaboss (07-18-2018)
The car only shows gains the first couple days an item is added, and after that, it re-adjusts.
#33
the x pipe without the cat will benefit your power as well. Catless downpipes will be beneficial also when the time comes.
Until then, you are fine. These mods WILL currently help when you get into higher altitudes.
Once your warranty is up, you can tune it, and thats that, youll make over 100 more hp in a heartbeat.
#34
when it gets cold, your car will go into limp mode on highspeed runs. When it does, PM me in here.
How long have you had the vehicle?
#35
No nothing personal but I have seen this in threads before. Change the xpipe back it to stock it adds the least and causes the trouble. The BMS you want to use and the MAMO
#36
Take it to the track and see what the trap speed is. That will give you an indication of how much power you are making. I would trust a time slip before a dyno.
The following 2 users liked this post by 383vett:
AZGASSER (07-18-2018),
Mike Jesse (07-19-2018)
#38
#39
After doing a lot of research on this site I decided to add the following popular "warranty safe" no tune mods on my car in this order:
Borla X-Pipe with secondary cat delete
BMS Air Filter
Mamo Portal Throttle Body
I did a stock baseline dyno and after I added each mod separately I drove the car a few hundred miles to let the stock calibration adjust. The BMS Filter did throw a code which I was able to clear and it didn't come back. My 17 Z06 M7 is running the latest stock calibration offered by GM as of May 2018. I had the car dyno'd again on the same dyno and it's pretty much putting down the same power but now running pig rich. My first though is that GM has changed the OEM calibration significantly to over correct instead of letting things lean out. Looks like it might be game over for no tune mods on later Z06s. Thoughts?
Stock Red, Mods Green
BMS Air Filter
Halltech and Corsa X-pipe took me from 578 - 613 without a tune the OEM air box is a joke
#40
There is a lot more going on behind the scenes in these cars WITH THE STOCK TUNE... than even the best tuners are still aware of.
