ATI super damper systems in stock and on sale at Juiced Motorsports
LT1 to LT4 build
I have a stock bottom end C7 Z51 Dy Sump.
adding an LT4 Supercharger with a griptec 2.31 upper pulley, 100mm idler pulley. Scupercharger was completely ported by Boost Mode. 103mm throttle body, Haltech intake, LT4 injectors, HPFP. Alkycontrol x2 nozzles. Texas Speed Heads and VV2 Cam.
i daily drive this car and take it to the drag strip most Sundays when it is above 50F and dry.
I have an ATI 917315 and need to know which lower pulley Is correct? I don’t want to over heat the SC and. Abuse more problems with reliability.
I currently have a 2.38 upper with the following mods:
Kong Ported blower and snout
Port matched LT5 throttle body
NX blower lid
fasterproms thermal reduction plates
160 stat
Cordes 5” CAI
Cordes heat exchanger
Norcal cat delete pipes
Borla X-pipe
BBE axleback
Brisk one heat range colder plug
Granitelli plug wires
I’m running right at 11psi and would like to safely raise boost higher. What overdrive would you recommend with future mods being a JMS voltage booster, LPE high pressure fuel pump, flex fuel sensor and e40-e50?
Can you sell me a pulley, ATI damper, idler pulley and belt all together?
NX blower lid
160 stat
Cordes 5” CAI
Borla X-pipe
BBE axleback
#33
Former Vendor
Yes, you can order them online with the pulley ring and belt. We have run the 15% overdrive pulley with the 2.3 upper on a lot of builds. It looks like you have everything else in line for higher boost.
