Alignment Problems
Old Aug 13, 2018 | 12:11 PM
jvp's Avatar
jvp
"Ask Tadge" Producer
Default Alignment Problems
And this, kiddies, is why we don't run too much negative camber on the road. No, it's not due to toe (which is 0). It's the negative camber. God. Dammit!
The one on the right isn't looking any better.
Old Aug 13, 2018 | 12:25 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Is that with the factory alignment? I have yet to see any tire worn incorrectly on any of my Corvette's.
Old Aug 13, 2018 | 12:40 PM
jvp's Avatar
jvp
Track alignment, not street. I'm going to have to dial it back a bit before getting the tires replaced.
Old Aug 13, 2018 | 02:06 PM
rico750sxi's Avatar
rico750sxi
Do you remember the specs to which you had it aligned? Was it the GM track alignment spec, one of the DSC specs, or your own? I'm getting my alignment done Friday and haven't yet decided on how aggressive I want to get.
Old Aug 13, 2018 | 04:05 PM
jvp's Avatar
jvp
Here's the print out when they were done:
Old Aug 13, 2018 | 04:58 PM
rico750sxi's Avatar
rico750sxi
Thanks, how many miles did you have on the alignment? I was going to get it set close to your settings but now I’m reconsidering and maybe I’ll split the difference between DSC street/occasional track settings and their street/ heavy track settings.
Old Aug 13, 2018 | 05:23 PM
jvp's Avatar
jvp
5000 miles.
Old Aug 13, 2018 | 06:50 PM
rico750sxi's Avatar
rico750sxi
5000 miles.
Old Aug 13, 2018 | 07:01 PM
thebishman's Avatar
thebishman
I did a combined total of 10,000 miles with my front alignment at -2.2 and my rears at -1.8; 8,000 of those miles on the original MPSS. I never experienced ANY increased wear on the inside of the front tyres; in fact wear was equal across the face of the tyres.
Check your alignment settings, especially the toe.
Bish
Old Aug 14, 2018 | 09:48 AM
Mad Dog 24's Avatar
Mad Dog 24
From: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
JVP, that is not common. We run about the same camber as Bish on the street and have set up many others similar. I would be checking wheel bearings and ball joints next as you probably will being a tech contributor. We had an older Volvo in a few years back the factory spec for the rear camber was -2.4 degrees..... factory! Please post any odd findings if any as your alignment numbers look fine.
Old Aug 14, 2018 | 10:08 AM
Mr. Gizmo's Avatar
Mr. Gizmo
I recently had a street alignment on mine.
The caster on both fronts was set at plus 7.2. From the factory it was at caster 7.8.
Your left front is plus 7.9 and right front is minus 8.2. That’s very odd. While it seems camber would cause your tire problem maybe tou hit something on the right front jolting caster out of whack and the way the tire is loaded during a turn ruined your tire.
Old Aug 14, 2018 | 10:36 AM
jvp's Avatar
jvp
Five thousand street miles(!) shouldn't have caused that, though. Again: these are my street tires; they've never been on a track. I have the Cup2s for that.
Old Aug 14, 2018 | 11:34 AM
Mr. Gizmo's Avatar
Mr. Gizmo
keep us posted on the problem. These cars are heavy , eat tires and wheels/suspension are fragile. Running over an ant messes them up. So it’s not surprising. Especially with the radical difference in caster from side to side. That doesn’t seem right.
Old Aug 14, 2018 | 06:28 PM
Takoyaki's Avatar
Takoyaki
I run -3.5 degree of camber on my autox car and I am not getting anything like that. I drive to each events and not trailered so it should add up to few thousand miles. I think toe wear causes that type of wear on the edge. You may want to ask the shop which did your alignment to see if their machine is calibrated.
Sorry about your tires.
Old Aug 17, 2018 | 11:03 AM
jvp's Avatar
jvp
I still haven't gotten the car on an alignment rack to figure out what's going on and whether it's still the same as before. I'm starting to believe that it may have magically adjusted itself since the camber blocks were install back in April of 2017. I've been dealing with annoying alignment issues since owning the car and I've never gotten them nailed down; I mistakenly thought I had once the blocks were installed.
This, combined with the clunk I hear when I go over a bump. I've tried recording it and uploading it here on the forums, but everyone says I'm crazy and there's no noise. It's there. Any time the car launches over a speed bump (suspension extends) and lands (suspension compresses) there's a rattle that I hear from the front end. My service folks have never been able to reproduce it and they insist everything's fine.
I suspect these two things are related, but when it comes to suspension: I'm not sure where to look (other than under the car. ). I can put the car in the air as I have a 2-post lift here at the house. The rattle has been there since I purchased the car, so it has nothing to do with the camber blocks that were installed. Since we know the camber can't adjust itself at the upper and/or lower control arms now, and everyone seems to think it's the toe that's out: where do I look? What things could be moving around that would muck up the toe, and potentially rattle over a bump? Sway bar? Something else?
Old Aug 17, 2018 | 12:44 PM
Takoyaki's Avatar
Takoyaki
I had the clunking noise issue on my C6. It was the top hat for the aftermarket shock getting loose.
In terms of your alignment, I would take the car to different shop and get the alignment done. Right after you come home, mark up all alignment related bolts and nuts with a Sharpie so you can check later if they have moved. Your alignment should be bad to start with or something is shifting.
Old Aug 17, 2018 | 10:31 PM
Mad Dog 24's Avatar
Mad Dog 24
JVC, Some early C7s had an issue with one of the front ball joints making a noise while turning if I remember correctly. A bad ball joint could change camber and toe. GM may have a tsb on this issue. We check ball joints by lifting the car off the ground 3 or 4 inches and take a long bar for a lot of leverage stick it under the tire and lift. Best done with 2 people as one can watch the ball joint and control arm movement. This duplicates in some ways the car hitting a bump in the road. Also clicking noises in the suspensions have been found to be at the wheel hub surfaces being dirty. I hope this helps. Remember any alignment guy can cheat the numbers you see on the paper..... just saying!!
To Alignment Problems
Old Aug 19, 2018 | 04:12 PM
jvp's Avatar
jvp
I put my car up on my lift this morning. Both fronts are in pretty bad shape, but the driver's side is much worse. When the toe was last set, the alignment ship did paint the nut on each side. Neither has moved. So either they set a bad toe value, or something else has moved since then. Bearing in mind they installed camber blocks when they did that alignment, so the camber couldn't have changed. At least: not where the LCAs attach to the cradle.
Old Aug 19, 2018 | 05:09 PM
atljar's Avatar
atljar
If it was toe caused, you would see equally poor wear on left and right tires. So that leaves loose suspension item or camber
Old Aug 19, 2018 | 09:22 PM
trevor90's Avatar
trevor90
so if you take your car to the dealer and tell them to align it to "street spec' they should know what to do?
