DeWitts TOC/EOC Combination system
#101
Former Vendor
However it seems we can gain quite a bit on the depth as 9" fit fine on a z51 with a bit of wiggle room infront of the intercooler still. Maybe 2". None behind. None.
Putting the fittings on the side under the area that is blocked by the width of the shroud would allow a deeper core. Just thinking out loud here.
Example
I'm starting to wonder if you and I are the only ones reading this post?
#104
I, and hopefully many others, are following your progress on this Tom. I think your approach with the dual coolers in this location is a genius idea with the added benefit of not having to take the front fascia off to install. I would most likely go with your TOC/Aux engine coolant set up with the larger Dewitts radiator for my '17 Z06 A8. Thanks for sharing your design, technical explanations, and being open to feedback. Much appreciated.
#110
Former Vendor
Former Vendor
Ditto. Reading and following closely. I used one of your radiators on my C6 Z and it was fantastic. Once its all put together, I will be a buyer. Any issues running your heat exchanger, radiator, EOC and Aux radiator all together with each other from a fitment standpoint (M7 car)
#113
Thanks Tom for the work you have put into this project. I am not concerned with trans temp on my 16 A8 since I will not be road racing the car. The only racing I will be doing is drag racing. Some time ago I installed a Cordes intercooler HE, a 160 tstat & Fasterproms intercooler tank to help with blower temps. I did not go with you're larger radiator at the time (would have been more cost effective) because of some people here that had concerns about air pressure drop across the larger HE & radiator. Apparently these concerns have proved groundless. So I am assuming all I would need to complete the cooling mod upgrade for street & occasional drag strip use is the larger radiator.
#114
Tom, your racing radiator should show up at my door any day. I didn't realize we have the same car 2016 Z06 A8, so whatever works for you will work for me. Is there any reason I should wait to install the racing radiator until I get the rest of the parts when you finish the design?
#115
Tom, I, too, have been following your progress with the hope of adding the TOC/EC option. In reading some of the latest posts, I have started to wonder about fitment. I see how close the tolerances are for the manifold piping and having an aftermarket heat exchanger(Cordes), have wondered if the extra thickness of the core will leave enough room.
#116
Former Vendor
#117
Former Vendor
Former Vendor
It should be okay. I have no experience with the Cordes but it looks to be the same thickness (2.25") as the DeWitts. Very close, but not a problem
#119
Former Vendor
#120
Not really, the radiator install is mostly done from the top and doesn't involve the chin components. As I said above, if it is the race 70mm (1149114M) model, you will have to trim the face of the fan and chop off the upper brace. I wish I had better instructions to send you but here is a marked up image of what it should look like
