Post your mod list
Old Mar 3, 2019 | 11:34 AM
cvp33's Avatar
cvp33
Default Post your mod list
I did a list like this for my 2012 CTS-V coupe. Always shocks me when you catalog everything you've done or will do to your car..Would love to see other's list, here's mine:
1) EOS carbon fiber front splitter
2) EOS carbon fiber side skirts
3) APR carbon fiber hood vent
4) APR carbon fiber wheel spats
5) eBay clear wicker
6) GM stage 3 spoiler
7) GM stage 3 winglets
8) ZL1 add-ons front/rear tow hooks, Orange color-matched
9) C7.R orange decals - winglets, clear wicker, steering wheel
10) Carbon fiber seatbelt tender
11) Carbon fiber exterior door pockets
12) Carbon fiber center counsel overlay
13) Carbon fiber steering wheel overlay
14) Carbon fiber door locks overlay
15) GM racing Jake decal
16) Lloyds C7.R front mats
17) Lloyds Z06 cargo mat
18) McGuard black lugnuts and locks
19) Z06 valve stem covers
20) GM CAI
21) Hawk DTC racing pads
22) Castrol SRF brake fluid
23) Deity Signature forged 18" racing wheels
24) Toyo R888R 315/30F and 335/30R
25) Custom painted Orange shift paddles with new REV MATCH decals
26)) VIR track decal
27) Custom Center caps (inbound)
28) C7.R door sills, custom Orange vinyl "R"
29) C7.R dash plaque, custom Orange painted "R"
30) Stinger hood stripe
31) Blackout vinyl for 6 exterior lights/reflectors
32) 4 Thermal blankets for CATS and trans tunnel
33) Z06 license plate bracket
34) Custom wicker hardware, black anodized versus GM's cheap looking screws
35) EOS rear diffuser fins
I know that's a lot. Some subtle, some not so subtle. The Z06 is a great platform to customize.
Old Mar 3, 2019 | 01:25 PM
Harbgrogan's Avatar
Harbgrogan
1. driver
Old Mar 3, 2019 | 01:33 PM
cvp33's Avatar
cvp33
Originally Posted by Harbgrogan
1. driver
Welcome to the forum. Driver mod is a good place to start, especially if this is your first Z06. The learning curve can be steep, especially on a track. Enjoy.
Old Mar 3, 2019 | 04:09 PM
Mikec7z's Avatar
Mikec7z
1. driver
Same
2. DSC sport alignment and DSC controller
3. BMS air filter
(and right now the car is being used as a guinea pig, all torn apart, for mock up of the cooling system I will need on my next car which will have upgrades and be taken to the track often enough to need to be cooled down)
Old Mar 3, 2019 | 04:14 PM
Monkey D. Luffy's Avatar
Monkey D. Luffy
Jake floor mats
Old Mar 3, 2019 | 04:21 PM
Z0HS1CK's Avatar
Z0HS1CK
BMS filter
Borla x-pipe
Katch PTB
That's it for performance.
Block it foam mats (i know, why did i do that? When changing out the RF's was all i needed to do lol).
Full stage 3 front spoiler with winglets
Forgestar wheels
I'm done with all modifications. Deciding on getting the DSC controller though. It'll be hard to justify spending 1300 bucks on a car i only drive on weekends and since i'll be trading soon (hopefully for the C8), it makes no sense at this time of ownership. I should have gotten the DSC when i first got the car.
Old Mar 3, 2019 | 11:17 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Custom-painted Shark Gray hood stinger & extended roof/hatch stripe and Arctic White roof rails on transparent top (Local body shop)
Paint protection film and window tint (Local film/tint shop)
Forgeline Monoblock wheel/tire/sensor package - AR1 Transparent Smoke and Michelin Pilot Sports stock sizes (CWFL)
Custom Steering Wheel & Horn Pad (Caravaggio)
T10 LED cargo and rear license plate bulbs (Amazon)
Custom-painted Carbon Flash wheel spats, ACS front splash guards, GM rear splash guards (RPI Designs)
Custom-painted Shark Gray hood heat extractor, intake cover, inner fender covers, alternator cover, and oil dip stick handle (RPI Designs)
American Car Craft Z06 M7 Engine Cap Set (RPI Designs)
Borla 60547 X-Pipe (RPI Designs)
Custom-painted and airbrushed Shark Gray coil covers, supercharger cover & fuse box cover (Showstopper Accessories)
Lloyds Z06 floor and cargo mats (CCA)
C7 Dual Travel Buddy (CCA)
C7 Bin Buddy (CCA)
LED clear side markers and tinted rear markers (GS Creations)
Coupe partition (Exotic Vettes/Crazy Cowboy)
ProTEKt Z06 Skid Plate Kit (ProTEKt)
Escort MAX 360c detector w/Blendmount (Direct)
MGW C7 Short Throw Shifter (Direct)
Tony Mamo Ported LT4 Throttle Body (Direct)
Block-It sound deadening kit (TKO Performance)
Old Mar 3, 2019 | 11:34 PM
X25's Avatar
X25
Sr.Random input generator
From my build thread:
[[b]Current mods list. THIS POST WILL BE KEPT UP-TO-DATE
Refer to my '16 Z51 mods list for a lot more.
  • Engine / Powertrain
    • ​Power steering gear cooling duct instructions. 30.
      • ​Duct (15842373)
      • Rear Deflector (23135212)
    • BMS drop-in air filter.
  • Interior
    • Sharkbar gloss black (9.7 lbs) and BK harness tabs. 85.
    • Schroth Profi II ASM race harness in black.
  • Handling
    • Alignment: -2.7, 7.8, 0 Front, -2, 0.8, 0.05 Rear (Camber / Caster / Toe). 63.
    • Tires / Wheels
      • 2 x Signature SV502 wheels at 18"x11" ET38 (21 lbs), 19"x13" ET56 (23 lbs). 115.
      • Forgestar CF5V 19x10 ET30 front (23.26 lbs), 20x12 ET59 rear (27.32 lbs).
      • Gorilla racing lug nuts (42133Ti) 0.6 lbs.
      • Michelin PSS ZP 285/30/19, 335/25/20 on Forgestars
      • Toyo R888R 315/30/18 (31 lbs), 345/30/19 (36 lbs) on SV502
      • Hoosier R7 315/30/18 (27 lbs), 345/30/19 (30 lbs) on SV502
    • Brakes
      • C7 Z06 front (13.5 lbs; loaded) and rear (6.7 lbs; loaded) brake calipers (370 mm; link). 5.
      • Girodisc Z06 front (22.9 lbs) / rear (17.5 lbs) rotors. 5.
      • Raybestos ST43s (For fronts, pad shape 1382.16 looks to be a better fit than 1405). front, rear.
  • Fluids
    • Engine oil: Mobil1 ESP 0W-40 (dexos2).
    • Differential oil: GM 88862624.
    • Transmission oil: Amsoil Signature Series Multi-Vehicle Synthetic ATF.
    • Brake fluid: Motul RBF 600.
    • Coolant: GM DexCool.
    • Suspension grease: Amsoil Synthetic Polymeric Truck, Chassis and Equipment Grease, NLGI #2.
  • Weights (of parts not on listed above)
    • Suspension
      • Lug nuts
        • OEM 2.2lbs.
        • Improved Racing Alu 1.1lbs.
        • CCW chrome 2.7 lbs.
      • Wheel/tire combos
        • MPSC 2 ZP + Stock Z06: 56.5 lbs front, 62.0 lbs rear.
        • MPSS ZP + Forgestar CF5V 19x10 ET30 front (54.1 lbs), 20x12 ET59 rear (62.1 lbs).
      • Tires
        • Hoosier R7 335/30/18: 28 lbs.
        • Hoosier R7 345/35/18: 29 lbs.
        • NT01 275/35/18: 27.3 lbs.
        • NT01 315/30/18: 30.4 lbs.
        • NT01 305/30/19: 31.5 lbs.
        • NT01 325/30/19: 32.3 lbs.
        • Pirelli DH Scrub 305/645/18: 25.2 lbs.
        • Pirelli DHC Scrub 325/660/18: 22.4 lbs.
  • Other / Discussions
    • How-to
    • OEM (Bosch) Digital Angle Gauge Adapter. Needed to adjust rear caster (CH-47960-10).
    • In search of affordable and strong wheel options (link).
    • Dyno results (1/12/2019). 69.
    • Oil sample results:
      • @465 miles 110.
  • Archived
    • BC Forged RZ39 wheels 18x11 ET38 front, 18x12.5 ET59 rear; knurled bead option. 30, 95.
Old Mar 4, 2019 | 12:18 PM
cvp33's Avatar
cvp33
@X25 now that’s a list. No surprise as I know you’re a track rat like me. Well not like me, you can actually drive.
Old Mar 4, 2019 | 12:45 PM
X25's Avatar
X25
Nah, we're all in the same boat, unless we can get to the levels of pro driving. That doesn't seem to happen when you only do it as a 'hobby' : ))
Old Mar 4, 2019 | 12:57 PM
timmyZ06's Avatar
timmyZ06
How,s the EOS splitter and side skirts?? Did you install the fins yet??
Old Mar 4, 2019 | 09:34 PM
cvp33's Avatar
cvp33
EOS splitter is on par with C7 carbons products, so pretty good. The side skirts are thin though. Thinner than C7 carbon. And no I haven't put the rear fins on yet. Waiting for a day over 60* so the paint will lay right.
Old Mar 4, 2019 | 09:50 PM
Steve Garrett's Avatar
Steve Garrett
CORVETTE TODAY Show Host
CORVETTE TODAY Host
St. Jude Donor'15
Please see below...
Old Mar 5, 2019 | 04:18 AM
Amirns's Avatar
Amirns
Performance mods:
1) Mamo ported throttle body
2) BMS air filter
3) Corsa x-pipe
4) Corsa xtreme
5) DSC controller
Cosmetic mods:
1) Apr wheel spats
2) Apr side vents
3) Apr rear spoiler
Coming soon:
1) Apr rear quarter panel ducts
2) Apr hood vent
3) Anderson composite rear diffuser
Also thinking about Anderson composite fenders but not sure yet, as you can tell im all about exposed carbon fiber lol
Old Mar 5, 2019 | 07:49 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Borla catless X-Pipe
Mamo Ported Throttle Body
That's it aside from some track time. The reality is, these cars, in stock form, exceed most owner's ability to drive them anywhere near the limit.
Old Mar 5, 2019 | 09:29 AM
FLEXjs's Avatar
FLEXjs
Mine is in storage but I have some goodies ready to go when the weather warms up:
  • Borla X-pipe
  • Oracle Color-matched and tinted LED side-markers
  • Mamo PTB
  • Weathertech cargo mat
Still to come:
  • AFE Momentum intake
  • Tint
  • Engine bay dress-up goodies (still deciding what to get)
Old Mar 5, 2019 | 03:05 PM
Panth3r's Avatar
Panth3r
I'm not a track guy (scared to add that addiction to my current mod disease) ZO6 is plenty fast for my use. I'm focused on appearance mods. I love the look and legacy of the vette but don't like being in a cookie cutter looking car. I mod every car to my taste. I'm just getting started but have plans.
Ivan Tampi rear spoiler
C7 carbon GTX side skirt (not installed)
ADPM Rear hatch(not installed)
ADPM front bumper(not installed)
ZR1 replica wheels powder coated illusion cherry
I
To Post your mod list
Old Mar 5, 2019 | 08:51 PM
cvp33's Avatar
cvp33
@Panth3r I'd never heard of ADPM. Had to google some pics. Wow, you must post up once you get everything installed.
Old Mar 5, 2019 | 09:20 PM
Panth3r's Avatar
Panth3r
Definitely here’s a pic of the wheels
Old Mar 6, 2019 | 12:20 PM
Kazman1960's Avatar
Kazman1960
Cosmetic Mods .
(1) GM stage 3 spoiler
(2)GM stage 3 winglets
(3) Carbon fiber front splitter
(4)Carbon fiber side skirts
(5) Clear Wicker.
(6)Lloyds Z06
(7) Epel protection
(8) Arctic White painted Valve covers
Power Mods ,
(1) F1A-94Pro charger ,
(2) Lingenfelter Cam ,
(3) Lingenfelter Crank Pulley ,
(4) Rocker arms and spring kit ,
(5) Low side fuel upgrade ,
(6) Alky control triple spray meth kit ,
(7) Catch can ,
(8) Corsa Cat back ,
(9)1 7/8 long tube headers
