Shock controller issues
1. 2015 M7 Z06 (I ordered in 2014 and have had since mid December 2014)
2. mods include ported throttle body, CAI, Borla X pipe and axle back, and DSC shock controller
3. approx 40,000 Miles
The last few times ive driven this car I’ve gotten a “service suspension system” message. After researching and reading on here, I chalked it up to bad connection at the DSC controller, knowing I’d eventually get around to pulling it out, and reinstalling it to make sure it’s seated well with the harness. Keep in mind, the warning has been intermittent.
This morning I drove this car for work, knowing I’d be on a long windy stretch, perfect for a spirited drive. Wouldn’t you know it, got the same message in the DIC. Then, while driving, the DIC said “speed limited to 85 mph” any time I got close to 80. I figured it was the computer somehow limiting my speed in case there really was a suspension issue.
Decided I’d open up the fender and uninstall/reinstall the DSC when I got home, so I did. To my surprise, the car suddenly wouldn’t start at all. All I got was the “press clutch to start car” message on the DIC. I fidgeted with fuses, uninstalled and reinstalled the DSC controller several times, even swapped out the clutch pedal switch (it was cheap and actually in stock locally). Still nothing. Not even a clicking sound at the starter. Battery said 80% at this point.
I had given up all hope, thinking I’d better button her up so tomorrow I can roll her about twenty feet forward where’d she’d be over my pit, so I could start checking for power at the starter. I’m not sure why, but on a whim I thought I’d try the stock shock controller. Plugged it back in, and whatdya know, she started right up. It’s the damn-dest thing I’ve ever seen, a shock controller keeping the ignition from cranking the engine...or was this just a weird coincidence? I’m going to check for codes, but also curious if anyone else has had similar shock controller with “no start” issues?
General Motors Local Area Network (GMLAN) is an application- and transport-layer protocol using Controller Area Network for lower layer services.
https://en.wikipedia.org/wiki/Genera...l_Area_Network
Bill
