AWE X-Pipe Center Section - C7 Corvette
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Built with Performance in mind the AWE X-Pipe delivers on all fronts.
Manufactured with the Highest Grade US Sourced T304L Stainless Steel,
and guaranteed not to trip a CEL Code. Deepen and Broaden the sound of
C7 Corvette with an AWE X-Pipe. Fitment for Stingray, Grand Sport and Z06/ZR1
C7 Corvette AWE X-Pipe
Regards
Chip
2.75" or 3.0" ID piping?
Have not seen any for just the X-Pipe
but
This is what AWE is showing for the entire system
Peak gains of 18 hp and 16 ft-lbs of torque, and max gains of 22 hp @ 6400 rpm and 20 ft-lbs of torque @ 4000 rpm, at the wheels
(Performance X-pipe + Touring Edition Axleback Exhaust)
Regards
Chip
but
Regards
Chip
The following 2 users liked this post by 06mikez06:
CCA Corvette Parts (07-11-2019),
usrodeo4 (07-10-2019)
Exactly - Borla 60547 customers are flooding to this unit
FYI I have 6 of them left
Regards
Chip
You do not need to loosen the motor mounts - it's a straight bolt up
You leave the current O2 wires exactly where they are (you will not touch them)
Your car has 4 cats, 2 primary and 2 pup cats. The O2 sensors are before the
main cats and directly after them.
The pup cats on all C7's are behind (rearward) of the final O2 sensors.
The pup cats are 100% un-monitored
Removing the OEM X-Pipe and replacing it with a catless unit will NOT trip a CEL
because the car does not know the difference
Regards
Chip
