Normal operating temperature
Old Apr 26, 2020 | 04:06 PM
joemessman's Avatar
joemessman
Default Normal operating temperature
I noticed today that in this 100 degree heat my engine and oil temperature run around 216 degrees. Is this normal?
Old Apr 26, 2020 | 05:08 PM
rhneff's Avatar
rhneff
City/highway driving?
What model C7 - standard/Z51/Z06?
What transmission - auto/manual?
"Spirited" driving or just normal street driving?
Not sure there is a "normal" on temps but certainly would help responding if more detail was provided.
Dallas temps Friday were 90+, Normal street driving in my 3LZ Z06/Z07 temps were water/199, oil/201.
Old Apr 26, 2020 | 05:15 PM
joemessman's Avatar
joemessman
Stop and go around town.
See my signature for the car details.
Old Apr 26, 2020 | 11:06 PM
ersatz928's Avatar
ersatz928
Normal. Oil temp usually runs 5 to 60 degrees higher than the coolant temp.
Old Apr 26, 2020 | 11:08 PM
BrunoTheMellow's Avatar
BrunoTheMellow
It's a little warm. But ok for an a8. If you see >220 or 225 your tstat might be getting stuck. Check if you have enough fluid in your overflow tank.
Old Apr 27, 2020 | 08:13 AM
rtv900's Avatar
rtv900
not mine
normal driving my oil is just below 200
same with coolant
Old Apr 27, 2020 | 08:47 AM
joemessman's Avatar
joemessman
I went for a drive yesterday afternoon on the highway and it stayed around 200 or so for both oil and engine temps. Ambient temp was 103. Must have been the stop and go driving in the hot 100 degree temps in the city that heated to the 216 range. All is good.
Old Apr 27, 2020 | 11:26 AM
BrunoTheMellow
Can't cool down if the air going through the radiator is the exhaust from the car infront of you
To Normal operating temperature
