02 Simulators
Old Sep 1, 2025 | 11:22 PM
kevin nguyen's Avatar
kevin nguyen
1st Gear
Originally Posted by big bollas
You set then up the same way and you should be good.
If you run the headers you will want to tune it and if you do so you can just have the secondary O2's shut off and you would not need them at all.
quick question when you installed the catless down pipes did you have to disconnect the car battery
