PF 64 filter
Old Nov 10, 2020 | 09:06 AM
mnl119's Avatar
mnl119
Originally Posted by rtv900
What am I missing here?
If I look at my oil pressure reading it is typically in the 40 psi range.
Everybody is saying the filter bypass is 15 psi.
Doesn't that mean the filter will be bypassing 100% of the time?
Am I misunderstanding something about this?
The pressure differential you see on the gauge is the difference between the exit of the oil pump and atmospheric. the bypass setting is what the valve is set to open at when the pressure differential is 15 psi (or more correctly for our cars 22 psi) across the filter.
Old Nov 10, 2020 | 02:01 PM
Gucci Minh's Avatar
Gucci Minh
A lot of bs gets spread around the car community. Something as cheap as an air filter would be the first thing to get recalled considering the damages if what is said is true.
If it makes you feel better. I put the PF64 on the car after I did my initial oil change about a month and a half ago. I've done three days at Virginia International Raceway with it. Does exactly what it should.
Old Nov 10, 2020 | 02:06 PM
rtv900's Avatar
rtv900
but doesn't that mean it will bypass 100% of the time?
it goes right to the filter from the pump doesn't it? so won't it always be above 15 or even 22 regardless?
Old Nov 10, 2020 | 03:09 PM
mnl119's Avatar
mnl119
No. The pressure drop across the filter might only be a couple psi, with the pressure drop across the rest of the system being ~40 psi.
Think of it this way, the oil just after the filter has to be at a higher state than atmospheric to carry it through the rest of the system.
Old Nov 10, 2020 | 03:43 PM
rtv900's Avatar
rtv900
ahhhh
so basically the filter has to start getting packed up and restricting in order to build up to 15 psi
if it's clean it will never get near that
Old Nov 10, 2020 | 03:48 PM
KLG's Avatar
KLG
For sure, this can be a little confusing. The oil filter by-pass pressure setting refers to the pressure drop across the filter.
For example, if the oil pressure entering the filter is 80 psi and the pressure exiting the oil filter is 60 psi, the pressure drop across the oil filter is 20 psi and the by-pass valve in the PF64 will not open. But if you were using a filter with a 15 psi by-pass valve (PF48, RP 10-48, etc), it would open and send unfiltered oil through your engine needlessly.
Now if the pressure entering the filter is 80 psi and the pressure exiting is only 50 psi, then the PF64 by-pass would open to keep from starving the engine for oil.
However, If you use a filter with too high of a by-pass valve rating, such as a UPF64R (35 psi), and you had the same situation as above, you might starve the engine for oil since the by-pass would not open.
--KLG--
Old Nov 10, 2020 | 03:57 PM
KLG's Avatar
KLG
ahhhh
True, a restricted filter will cause a high pressure drop across the oil filter.
However, that is not the only situation. For example, operating in very cold temperatures might cause a high pressure drop across the oil filter on engine start-up, forcing the by-pass valve to open temporarily. Or using oil with too high of a viscosity, especially in cold climates might do it as well. Or starting up your cold engine and flogging it right away might also temporarily cause the by-pass valve to open.
--KLG--
Old Nov 10, 2020 | 04:21 PM
MMD's Avatar
MMD
https://www.corvetteforum.com/forums...-17-na-157.pdf
Old Nov 10, 2020 | 07:19 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Originally Posted by KLG
Agree, NAPA has good filters as well.
I don't know if it is still the situation, but, at one time, NAPA and Wix were the same, just different labels.
that’s the way I remember. Napa Gold = WIX.
Old Nov 10, 2020 | 09:23 PM
KLG's Avatar
KLG
And it may be now that the Wix XP filters are about equivalent to the NAPA Platinum.
Old Nov 10, 2020 | 10:47 PM
bhizzleZ's Avatar
bhizzleZ
Probably cheap insurance to use the OEM filter (PF64). Dealer uses it on my 2019Z.
Old Nov 16, 2020 | 10:12 PM
the blur's Avatar
the blur
What about the AC Delco UPF64R filter ??
Old Nov 16, 2020 | 11:19 PM
  #33
MMD's Avatar
MMD
Do not use this in your C7. It's for new smaller gasoline engines (according to GM), doesn't filter as efficiently as does the PF64, and the big kicker is the pressure relief valve operates at 35psi. GM strongly recommends an oil filter with a 22 psi pressure relief valve. PF64 is the way to go if you're under warranty.
Old Nov 16, 2020 | 11:21 PM
  #34
KLG's Avatar
KLG
That filter fits and a lot of people use it. Dealer put one on my car at the 500 mile oil change.
However, the oil filter by-pass valve setting is 35 psi in the UPF64R. The PF64 is 22 psi.
I recall the UPF64R is used on some of GM hybrid engines, I think.
See posts #7 and #28 for GM's service bulletin regarding oil filters for the LT1/LT4.
--KLG--
Old Nov 16, 2020 | 11:44 PM
  #35
MMD's Avatar
MMD
When my warranty runs out in a year I will make the switch over to using a NAPA Platinum if the pressure relief valve can be found to operate at 22 psi. It's probably one of the best quality oil filters you will find anywhere. Made specifically for synthetic oils. Quality filter inside using quality materials and solid engineering.
Old Nov 17, 2020 | 12:48 AM
  #36
KLG's Avatar
KLG
I think you are good to go with the NAPA Platinum. NAPA's spec sheet states the by-pass valve pressure setting is 22 psi.
--KLG--
File Type: pdf
Old Nov 17, 2020 | 12:52 AM
  #37
MMD's Avatar
MMD
--KLG--
Dayum! This filter might be too good to be used. It's more a work of art.
To PF 64 filter
Old Nov 17, 2020 | 08:27 AM
  #38
larryfs's Avatar
larryfs
The Fram Ultra has excellent reviews. It was top rated when i researched this in 2013. I use them on all my wet sump LS motors. However, I don't know about the PSI rating.
Old Nov 17, 2020 | 08:54 AM
  #39
MMD's Avatar
MMD
Any oil filter which does not meet GM's pressure relief spec should never be considered for use in your engine. GM has a TSB that discussed this topic. You really need to know what this value is. For the C7 LT1 & LT4 engines your oil filter needs a pressure relief valve rated at 22 psi. This pressure will assure maximum filtration of the oil flowing through the C7 engine and also will influence what materials engineers use within the filter.
Regarding Fram filters, they are not considered good quality by most anyone who tests filters. K&N, NAPA, Wix, Bosch are making some of the very best automotive filters you can find today. AC Delco is acceptable.
Old Nov 17, 2020 | 09:45 AM
  #40
larryfs's Avatar
larryfs
Fram & Fram Ultra are worlds apart. I don't follow oil filter reviews all the time. But when I was 10 years ago; the Ultra was on top.
