What size ARH headers
Old Apr 2, 2021 | 08:45 PM
Itsovr4u7's Avatar
Itsovr4u7
Default What size ARH headers
What size headers for 15% lower pulley and tune on a 2017 zo6? The 1 7/8 or just go 2”. And would you keep the borla 60547 or use the ARH x-pipe. Thanks in advance.
Old Apr 3, 2021 | 12:50 AM
EXCUSES.Z06's Avatar
EXCUSES.Z06
I went because why not.
Old Apr 3, 2021 | 11:02 AM
2ZORNOT2Z's Avatar
2ZORNOT2Z
I went 2" Kooks just to move more air but I also did flexfuel sensor, and 5" CAI to push more air into the engine along with the 2.3 upper. You will have to use the ARH X-pipe. The LTs won't bolt up to your X-pipe. If you don't plan on adding any more power the 1-7/8 are probably fine.
Old Apr 3, 2021 | 06:08 PM
Internets_Ninja's Avatar
Internets_Ninja
2 inch and no you cannot use the Borla X pipe
Old Apr 4, 2021 | 10:40 AM
speed4tu's Avatar
speed4tu
Go ahead and do 2". You will probably thank yourself later
Old Apr 5, 2021 | 08:40 AM
Commandercorvette's Avatar
Commandercorvette
while the 1 7/8 make more torque down low . the 2 inch headers generally move the hp and torque curve higher , while the gains may be minimal vs the 17/8 many engine builders and tuners such as myself think if your thinking of going bigger or doing more mods later down the road 2 inch is the way to go .
Old Apr 10, 2021 | 02:54 AM
JanosNFS's Avatar
JanosNFS
What are you using the car for?
Daily driver or road racing/track?
2" is going to give you more power on top but for track 1-7/8 will give you more torque to get out of the corners...
Just something to think about.
To What size ARH headers
