Sd card
Old Apr 16, 2021 | 11:56 AM
sammy burks's Avatar
sammy burks
Active Streak: 90 Days
Default Sd card
Which SD card does the data performance recorder performance system use
Old Apr 16, 2021 | 02:06 PM
JKU007FL's Avatar
JKU007FL
I used Sandisk 16GB SD card (SDHC) , I read here once that 32GB is the biggest you can use but I haven't try it. Also make sure you use the format function in the PDR.
Old Apr 16, 2021 | 03:10 PM
SladeX's Avatar
SladeX
You can put in bigger, just need to format it correctly so the SD card is usable.
Old Apr 16, 2021 | 03:47 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
I used the scan disk 32 GB. It worked right out of the box. You can use a bigger one, but you have to format it.
Old Apr 16, 2021 | 09:03 PM
jimbob8915's Avatar
jimbob8915
where do you insert the SD card?
Old Apr 16, 2021 | 09:06 PM
Sox13579's Avatar
Sox13579
I went with the Scandisk extreme pro 32GB without any issues.
Old Apr 16, 2021 | 09:07 PM
Sox13579's Avatar
Sox13579
The slot is located in the glove box at the upper left corner.
Old Apr 18, 2021 | 11:01 PM
Molly815's Avatar
Molly815
Format? How do you do this?
Old Apr 19, 2021 | 07:25 AM
rtv900's Avatar
rtv900
put it in a computer, go to "this PC" to view disks on the pc.
right click on that disk
Format Card will be in the menu that pops up when you right click
Just select it and click "format"
Old Apr 19, 2021 | 04:01 PM
rcgldr's Avatar
rcgldr
Originally Posted by rtv900
put it in a computer, go to "this PC" to view disks on the pc. right click on that disk Format Card will be in the menu that pops up when you right click Just select it and click "format"
Windows will not format a SD card greater than 32GB to FAT32.(it formats it to NTFS instead). You'll need a standalone utility to do that. I used a utility from "ultimate boot cd", which is a collection of utilities to create a bootable USB stick or burned to create a bootable CD-ROM. I'm using a 64GB SD card.
Old Apr 21, 2021 | 12:24 AM
Big Reds Z's Avatar
Big Reds Z
VETERAN
I use a 32GB, no issues, and it's in the glove box . I also see you can put an SD card in
the center console too, but I never tried that one (15 Z06) my 19GS
didn't have that in the center console but did in the glove box. Hey Bill, does your 15Z have that in your center console , and does it work ?
Big Reds Z
Old Apr 21, 2021 | 05:48 PM
Big Reds Z's Avatar
Big Reds Z
VETERAN
I found out about the SD card in the center console, It's for Music .
Old Apr 21, 2021 | 05:54 PM
Thomasmoto's Avatar
Thomasmoto
Default Z06
Big Reds Z
The one in the center console will not work for your PDR. The center one is for music. You have to use the slot in the glove box for the PDR.
Old Apr 21, 2021 | 07:30 PM
Big Reds Z's Avatar
Big Reds Z
VETERAN
Thanks for that info Thomasmoto, I did find out it was for music and not PDR.
Old Apr 21, 2021 | 08:32 PM
Thomasmoto's Avatar
Thomasmoto
Default Z06
👍copy that
Old Apr 23, 2021 | 10:08 PM
lordofwar's Avatar
lordofwar
dont use bigger than 32,doesnt like 64
Old Apr 23, 2021 | 11:11 PM
Elk's Avatar
Elk
64GB is OK, but you need to format the card FAT32. But this is a lot of memory and 32GB is plenty big.
Old Apr 24, 2021 | 05:46 AM
cvp33's Avatar
cvp33
On a side note...remember just 5 years ago these were $50. Now they’re $7 at WalMart and they don’t even lock them up anymore.
To Sd card
