E85 guys....
Old Aug 4, 2021 | 08:25 PM
1QUICK Z's Avatar
1QUICK Z
Default E85 guys....
Hey guys, for those of you running on a flex fuel sensor and stock pumps, are you mixing your ethanol with race fuel? I typically get my E40-E45 mixture with 93 octane but I was just told that it might help to add some 110 octane race fuel. I'm not really sure how that helps since my tune is looking for ethanol content.
Any advice or thoughts. Thanks!
Old Aug 4, 2021 | 10:45 PM
LuckyC7Z06's Avatar
LuckyC7Z06
Just run what you were tuned with and don’t overthink it.
Old Aug 4, 2021 | 11:05 PM
1QUICK Z's Avatar
1QUICK Z
I'm trying for a new PB so every little bit helps. I've run a 9.96 at 141 with very few mods but I want more!
Old Aug 5, 2021 | 10:43 AM
atljar's Avatar
atljar
If you are still getting timing pulled due to knock sensors, OR arent able to run max timing for peak power/tq, then 110 mixed in would help but may require a retune.
Old Aug 5, 2021 | 03:56 PM
TJay74's Avatar
TJay74
Unless you are knocking on E40 (E85 is 105 octane, E40 is around 98 octane) I would not mix in any other high octane gasoline. As mentioned it will require a retune since it will throw the stoich ratio off.
Old Aug 5, 2021 | 06:21 PM
Twin_Guns21's Avatar
Twin_Guns21
My tune is set to run on anything between 91 pump and E55. I typically run between E45 and E50 by mixing (at the pump) around a 50%/50% mix of 91 pump and E85. Sometimes it's a bit higher than E50 and sometimes a bit lower. Once you get the ratios right in your head, it's easy to calc without much effort.
Old Aug 5, 2021 | 09:35 PM
1QUICK Z's Avatar
1QUICK Z
This is what I do as well. I'm just trying to figure out if throwing 110 into the mix is even worthwhile?
Old Aug 5, 2021 | 09:55 PM
BooSSted's Avatar
BooSSted
Similar, I'm tuned for E40, achieve that by mixing 93 pump and C85. I do throw in some race gas on occasion just for peace of mind / "safety" on my track days, only if I have some on hand. Not s show stopper to me by anymeans. 93 + your E85 cocktail is just fine!
Old Aug 5, 2021 | 10:14 PM
1QUICK Z's Avatar
1QUICK Z
Cool, thanks man!
Old Jan 2, 2023 | 10:47 PM
dizwiz24's Avatar
dizwiz24
Hmm. I run it , but have Herko stainless fuel pump hanger, twin rxp 340’s, -8an feed; -6an return lines
a stainless micron mesh fuel filter and big 83? lb/hr fuel injectors that are rated for it
still going thru the stock aluminum rails.
i have an ethanol gage showing me the % in the tank. Though its not hooked to my ecm - just for my own knowledge
no issues with it sitting , and i let it sit over winter with a tank of it.
why i run e85:
i find i can run more boost /timing and it doesnt set off knock retard
Old Jan 2, 2023 | 11:24 PM
Kingtal0n's Avatar
Kingtal0n
Alcohol fuel is superior to race fuel for most applications
The only reason to add some racing-gasoline style fuels is if your injectors or fuel pumps are maxing out and you need the higher energy content per unit volume that gasoline fuels provide
Old Jan 3, 2023 | 09:51 AM
Internets_Ninja's Avatar
Internets_Ninja
Waste of money to mix 110 race fuel. E40-E45 is plenty enough octane and superior cooling to race fuel. Adding race fuel to Ethanol will net you nothing on your setup.
Old Jan 8, 2023 | 09:36 AM
Dcasole's Avatar
Dcasole
Originally Posted by internets_ninja
waste of money to mix 110 race fuel. E40-e45 is plenty enough octane and superior cooling to race fuel. Adding race fuel to ethanol will net you nothing on your setup.
^^^^^^^^^^^^^this^^^^^^^^^
To E85 guys....
