Is Caster Alignment Necessary?
Old Aug 30, 2021 | 02:19 PM
Twin_Guns21's Avatar
Twin_Guns21
Default Is Caster Alignment Necessary?
Simple question, is it necessary to get my caster aligned when having a four wheel alignment (toe and camber) completed? I've called a few alignment shops and they were all surprised to hear that I wanted my caster aligned and seemed to indicate that all they needed to do was align toe and camber. They essentially were saying that as long as caster was aligned properly out of the factory, there is no need to touch it. I don't track my car and all I'm going for with the alignment is a slightly aggressive street setup.
Old Aug 30, 2021 | 02:29 PM
2ZORNOT2Z's Avatar
2ZORNOT2Z
Yes, you should have the rear caster checked any time the rear alignment is changed. It should be set around 0.0 to 0.8, closer to 0.0 is better for typical street driving imho. They are probably saying that because they can't do it. You need a special tool to measure the angle for the rear caster which a typical tire/wheel shop won't have unless they do lots of C7s. Most cars don't have an adjustable rear caster and their hunter alignment machine won't measure it (only front caster) so they're probably not even tracking with what you are asking for. Take it to a place that can measure and set it properly.
Old Aug 30, 2021 | 03:25 PM
atljar's Avatar
atljar
Agreed. 99.9% of alignment shops will tell you rear caster is not measurable or able to be set. The alignment machine cant read it. The tooling required is a fixture that slides into your rear spindles, and an accurate angle gauge.
Old Aug 30, 2021 | 03:57 PM
bandit16ss's Avatar
bandit16ss
Navigator
I know that rear caster is a popular topic here, but the OP doesn't specify rear caster, just caster in general. That being said, yes, front and rear caster should be checked.
Old Aug 30, 2021 | 04:41 PM
atljar's Avatar
atljar
You are not wrong. With that said, if a shop is telling you that front caster doesnt need adjusted or set, then run away from that shop.
Old Aug 30, 2021 | 05:54 PM
SladeX's Avatar
SladeX
YES! I would get rear caster verified always on these cars. Mine came from factory with + on the passenger, and - value on the driver's side. This lead to the car rear snapping hard to the driver's side on hard launches, very violently I may add and gave me unusual tire wear in the middle of the passenger tire as the toe distorted significantly under load because of this. This made my Z06 terrifying even with the traction control full on as it'd have to recover hard from this every single hard launch
Old Aug 30, 2021 | 08:02 PM
Bill Dearborn's Avatar
Bill Dearborn
Are you talking about caster in general or rear caster? Anytime the front camber is adjusted on a C7 it will affect the front caster, the two adjustments affect each other.
If you are talking about rear caster you will run into a lot of confusion about that since it isn't a common measurement/adjustment on production vehicles. I only know of 3 production vehicles ever made that have adjustable rear caster, the Pontiac Solstice, the Saturn Skye and any C7 Corvette. Rear caster changes with camber in the rear as well.
In the case of rear caster, measurement requires special tools that aren't part of an alignment machine and without those tools the shop can't properly set rear caster. If all they do is measure and then set rear camber they have no idea what happened to the rear caster when they changed the camber.
Even Chevrolet Dealers have issues with rear caster although it is specified in the Factory Service Manual and the measurement/adjustment procedure is described in the same manual. A lot of us purchased our own rear caster adapters and measurement gauges and use them to set rear caster. I have even loaned my tools to the dealer mechanic so he could adjust the rear caster for me.
Bill
Old Aug 31, 2021 | 10:00 AM
Twin_Guns21
Thanks for all the great feedback. I called the dealership and they confirmed they could do the alignment. Should I confirm with the technician that they have the necessary tools? It's Rydell Chevrolet in Woodland Hill, CA.
Old Aug 31, 2021 | 10:06 AM
SladeX's Avatar
SladeX
Confirm they have the rear caster alignment tool on hand or you will be wasting your time.
Old Aug 31, 2021 | 04:08 PM
Bill Dearborn
I agree. You need to make sure they have the proper tools. The first problem you run into is the Service Writer and mechanic think you are talking about the front caster and they are sure they can measure it. The next question is do they have the tools and they say the alignment rack handles the measurement and of course it can't. You need to make sure they know you are talking about REAR CASTER, Rear CASTER Adapter and the REAR CASTER Gauge. Depending on how many people have inquired about rear caster it can take some time to get it through their heads what you are talking about. Been there and done that with 4 different dealers, like all humans they hear what they expect to hear not necessarily what they are being told. As a professor once told me Communication is an Unnatural Act.
Here is the GM Bulletin Advising Dealers on how to set the Track Alignment, How to adjust Rear Caster and Camber starts on Page 3:
Page 1
Page 2
Page 3
Page 4
Page 5
The procedure to adjust rear caster and camber is the same procedure called out in the Factory Service Manual. The only difference between this bulletin and the alignment described in the Factory Service Manual is the specified numbers for Camber, Caster and Toe.
Bill
Old Aug 31, 2021 | 05:47 PM
Twin_Guns21
Bill, you are the man. Thank you for that info.
Old Sep 1, 2021 | 06:31 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Out of curiosity, does the C8 have adjustable rear caster?
Old Sep 1, 2021 | 07:20 PM
Bill Dearborn
Yes, it does. Described in the OM just like the C7s. Spec'd at 0 degrees.
Bill
To Is Caster Alignment Necessary?
