wheels
Jan 24, 2022 | 09:33 AM
wheels
will 19x12s fit on my Z06 with Z07 brakes
Jan 24, 2022 | 09:56 AM
As long as they have the correct backspacing, yes. My rears are 19x12 with +50 backspacing and clear my ccbs fine.
Jan 24, 2022 | 02:11 PM
^^Generally speaking that may be correct, but I'd caution owners that wheel spoke design can also affect caliper clearance.
My suggestion would to confirm fitment of a particular wheel design with the seller or at least from an established CF member's direct experience.
Jan 24, 2022 | 02:13 PM
Quote:
Originally Posted by
Dmenace
Which wheel and offset are you considering?
Jan 24, 2022 | 06:31 PM
Yes absolutely, if we can help please Call/Text 440-915-6166
Have a Great Day!!
Jan 24, 2022 | 07:08 PM
if you can do a test fit
if your buying from a retailor ask for guaranteed fitment or money back
make sure you have them put on the invoice for a xxx Corvette Z06 with CCB brakes
Jan 24, 2022 | 07:10 PM
Measure your OEM rim:
inside space from rim to spoke where the caliper would be....that's your space
I understand you'll need min of 2mm gap between caliper to wheel spoke
Jan 25, 2022 | 12:47 PM
either Z06 or Grand sport repos with the 59 back space
