I tried E mode a little when I drove my Z06 home from Alabama 2800 mile trip had to play with some of the modes. I noticed the computer at 90 mph was saying i was getting 32 mpg.. lol That was last time I ever used E mode The way I usually drive probably more like 8mpg
I drove it back from Fl to TX and was unable to engage 4 cyl operation at any time except E mode when coasting or with VERY light throttle.
I realize that I didn't buy the Z for gas mileage but I wonder if what I experienced indicates something else.
Your thoughts. pls
At highway speeds AFM rarely activates since the engine load is too high. I don't have an A8 but my M7 rarely activates AFM when I am driving at 70 mph in 7th gear. If the highway makes a slight dip the engine will change to 4 cylinder operation but as soon as it encounters the next slight rise it shifts to 8 cylinder operation. At 75 mph the rolling friction and aero drag are so high the engine only shifts to 4 cylinder operation when the car is coasting downhill. AFM is only for light throttle low load conditions. One thing I did find out about AFM is if I place the transmission in 6th gear Vs 7th I can run at 70 with AFM activated a lot more. The extra torque generated by the few hundred rpm gained in 6th is sufficient to drive the car in 4 cylinder mode with higher loads. With the M7 the lowest gear that AFM will work in is 4th and it will activate 4 cylinder mode at least 50% of the time.
thanks Bill
i understand your response which makes sense.
However, the 2015 Stingray A8 that I am selling will shift to 4 cyl at 75 in 8th gear easily and stay there in E,T or S
So, I’m wondering if I have a torque converter problem (which my 15 had before GM) replaced it) or improper programming or ?
thanks Bill
your thoughts?
will
no. It’s because the z06 still continues to pull too much load for 4 cylinders at highway speed. Likely since it has to spin the supercharger at all times.
I think most agree that sounds normal, many use range disablers and such to get around it.. I would not be concerned. I can speak for the Z owners I know, we just don't care or drive much in the fashion that would allow 4 cylinder mode nor use economy mode...
thanks Bill
your thoughts?
will
it’s normal.
Or the difference may be the A8 torque converter clutch is disengaged and the slightly extra rpm/torque the torque converter transfers to the transmission is sufficient when the engine is running on 4 cylinders.
Bill
by “sufficient when the engine is running on 4 cylinders “ do you mean that the torque is sufficient to kick the 4 cylinder operation off and revert to 8 cylinder operation?
Bill
will
No. I mean the torque is sufficient to keep the engine in V4 mode. It doesn't need to have the extra torque the V8 would provide. The electronics determine whether it is in V4 or V8 mode by watching the power developed. The torque converter acts as a gear when the clutch is disengaged.
My 2017 Z06 Z07 package - seldom goes into v4 mode, especially since I installed both front and rear stage 3 aero (wicker full up and front wings). Before the stage 3 aero, it would go into v4 mode occasionally.
If I am on a downhill section of the freeway at about 65 mph and in eco or tour mode, it will sometimes go into v4 mode - I have to watch the dash to see that it changed - almost no noticable feel that the car has gone into v4 mode (very smooth transition).
Pretty much the same for me. I also have an A8 with stage 3 aero. It hardly ever went into v4 mode on the highway unless on a steep downhill. I went ahead and put a Range Device on it anyway.
Yup I have a 2017 M7 and even in Eco mode, v4 never activates if I'm going over 70mph. The only way to really make it work is to go 65mph in the right lane nice and slow. Then it will pop into V4 mode and you can "hyper mile" lol. While I never do this, I did test it out and was getting 26-28 mpg which is pretty amazing. If I ever need to get somewhere slow and lean, that is an option.
However, the car is no longer stock and I removed v4 mode in the tune long ago. I never use it and still get around 20mpg on the highway in v8 mode on E60 going 70ish MPH.
The aero pieces for stage 2/3 really kill the v4 mode on my m7. With stage 1 ish, I could get the v4 mode to activate in 6th gear (sometimes 7th) depending on how flat the road was and the load level versus speed. The stage 2 aero adds just enough drag that 7th is all but impossible unless I am going down hill and 6th doesn't do that much better in mileage vs 7th even when it does kick in.
the GM tech rep was in town today and he reprogramed the AFM to factory specs and now the AFM works as it should. The mpg shown when in V4 mode is lower than that on my 15 Stingray but that’s to be expected w the Supercharger.
now the mpg jumps from 19 to 24 when switching from V8 to V4
the tech rep stated that the AFM learns from how the car is driven. From the maint and repair record on th GM server, the first owner drove in a very spirited manner. So, apparently the AFM learned that it was not to be called upon so it reprogrammed itself down
a five mpg is not a big deal even at $6 a gallon but now I’m comfortable that there is nothing seriously wrong with the transmission
