Help Bleeding Intercooler Coolant Lines??
I have maybe 1-2 inches of air in my inter-cooler res and I have been following this video...
Basically, pop the top off, put some fluid in there, start and stop the engine, watch the bubbles come out.
My issue is that, even with air in the tank, tilting the car/not tilting the car etc. I don't really see any bubbles coming out. I ran the car hard yesterday to maybe "splash it around" in there, and did see SOME air at the top that I could fill in but nothing extreme.
Is this a slow, multi-day process one bubble at a time or am I missing something?
-Jared
-Jared
Well, I have a track day on Monday at BIR (MN) so we'll see how it goes. It's going to be 100*F
I live in MN, if anyone has a coolerbleeder and wants to help for later, that would be great.
When I switched SCs on my car two years ago I purchased this unit from Amazon:
I used a gallon plastic jug to hold my new coolant and another gallon plastic jug to catch the dispelled coolant that gets pulled into the tool when a vacuum is applied. I purchased a reinforced clear vinyl hose at Lowes. I used hose clamps to hold one end of a several inch long piece of that hose to the tool and another hose clamp to hold it to the intercooler fill port.
Here are some pictures showing the tool and how it was hooked up to the car.
This picture shows the tool connected to the Intercooler Fill Port. The nice thing about using a clear hose is you can monitor the progress of how much air is being removed from the system. I also have a DIY hand switch that lets me exercise the IC pump.
This picture shows how the tool is set up. The blue hose is the connection to the compressor, The gallon jug I used for the outlet discharge is shown behind the hood vent seal. The cloudy look around it is due to air coming out of the bottle with some moisture mixed in with it. It can get a little messy as it bubbles a lot. The hose going down and to the right is connected to the gallon jug that is used for the intake coolant. Just make sure the coolant in that jug is sufficient to prevent air from being drawn into the system when you trigger the vacuum fill.
It takes several hours of drawing a vacuum, and alternately turning the IC pump on and then off. Every time you turn it on there is a burst of fine bubbles that completely obstructs visibility through the coolant so you need to let the vacuum pull those bubbles out of the coolant before adding new coolant. I found that squeezing the IC hoses with my hands helped pull big bubbles of air out of the IC. The second picture down with the flashlight shining on the clear hose shows how occluded the coolant will look when the pump is turned on. I suspect that burst of small bubbles happens due to the low pressure (-25) causing the pump to cavitate the coolant.
Bill
pull bumper
pull right side brake duct
unbolt reservoir and tilt so air bubble goes to the ports of the tank. Using a cheap hand crank vacuum tool, pull the fuse for the pump and stick a wire between that fuse hole and the 12v stud. and that should be work. I got all the air out of mine without tilting the car. But I was also installing other stuff that required me moving all that stuff around.
-Jared
Bill
I also created this video review of the cooler bleeder,
The effort is well worth it though. Not having a well bled system will kill horsepower on the road course. On the street, it isn't as much of a problem.
https://www.youtube.com/watch?v=QgNS9fVJbco&t=244s
As usual, thanks for the great write up. I see how you have two buckets. One to catch the expelled coolant bucket (right side of car) from the tool (drawn through the venturi) and the fill bucket(left side of car). I did this method many times and it is messy and frustrating. While it is much better than just filling a hose and hoping it bleeds (like in my original video), it doesn't really solve the problem. It may be better to put a PVC pipe in the clear tube (so it doesn't fully collapse), but in my experience it needs to be 12"-18" long because the vacuum pulls the coolant up the tube. This is why you have the catch bucket on the right.
The Cooler Bleeder works better, because the vacuum chamber is so much greater in volume(than a hose) and it pulls 30" of Hg because of the A/C vacuum pump. I just want to make sure the original poster and other's realize why this is so difficult even with the generic coolant bleeder.
Bill
After the manual bleed I had two small bubbles in the tank Yada Yada Yada...
In automatic mode a shitload more air came out. That being said if the tank didn't have any air in it where did it come from lol. The bricks maybe.
That also means using the tanks air bubbles as a gage to the ammount of air in your system is complete not quite right.
My car runs stronger from 125mph to 140ish than it ever has!
If you can get your system bled with a cooler bleeder you'll see the difference for yourself.
