P0171 code
Old Sep 25, 2022 | 05:02 PM
Blackie2016's Avatar
Blackie2016
2nd Gear
Default P0171 code
Check engine light pop on last night, can’t find the problem,have Mighty Mouse catch can and had to adjust the location because I added gspeed heat exchanger reservoir tank. Checke all the vacuum lines for leaks and found none on Bank 1 side. Help please
Old Sep 25, 2022 | 05:13 PM
Blackie2016
2nd Gear
I also to replace the the supercharger heat exchanger because the OEM On my way! had a hole in and was leaking.
Old Sep 26, 2022 | 05:23 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
What happened after you cleared it?
To P0171 code
